Re: Creda TVS3 – Belt replacement – fitting
Anyway, well done Sheka.
Obviously the advice given on the site, and a sensible approach has paid off. As to the build up of fluff inside the machine I have found on several occasions this is due to an ill fitting extraction tube previously fitted by experts in the factory. As you are aware now of the build up, if it has happened on your next check, have a look at the pipe through which the air passes before leaving the vent to make sure it is sitting tight on the flanges.
(these words may not be the correct descriptive ones but you will understand what I mean)
Good luck.
