Crusader Condenser Dryer Sensorcare
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Crusader Condenser Dryer Sensorcare
Viewing 15 posts - 1 through 15 (of 21 total)
  • #21242
    cherryvale
    My Crusader dryer has been working well for seven years but has recently stopped heating. It is cleaned every day and everything else works ok but there is no heat at all. I’m guessing it’s the element rather than the thermostat. It’s a model 37667 and Espares carry the parts but before I jump I’d be grateful if someone could give me some idea if I might be right.
    Thanks.
    #190124
    Re: Crusader Condenser Dryer Sensorcare
    cherryvale wrote:I’m guessing it’s the element rather than the thermostat.
    My more informed guess would venture to suggest otherwise. 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure it is the thermostats at fault. 😉
    cherryvale wrote:and Espares carry the parts
    So do we here on this site, cheaper too! 🙂
    #190125
    cherryvale
    Thanks for that. I didn’t see the 37667 listed. Am I missing it?
    #190126
    Dave_Conway
    Could you post the serial number here please, 1701583 only fits your model after a certain date 🙂
    #190127
    cherryvale
    The serial number is 67100233.
    #190128
    Dave_Conway
    Thanks, the link Martin gave (1701583) is the right thermostat kit in that case 😀
    I don’t put some models in for this reason, people would order the wrong ones as it’s not always obvious which is which when Hotpoint decide to change the spec half way through production 😉
    #190129
    cherryvale
    That’s great. Thanks to Dave and Martin. I will now go straight to your store to order!
    Thanks again.
    #190130
    cherryvale
    Received the new stats.
    I removed the back of the machine to uncover the old stats. One was (?)ceramic as are both of the new ones but the other is black. The ceramic one had fallen apart. Which do I replace with the new ones?
    #190131
    The stat with the green spot goes on the left.
    cherryvale
    Thank you.
    #190133
    cherryvale
    Machine is working perfectly.
    Thanks for your help.
    #190134
    West
    Hello,
    I also have this problem with lack of heat. Pulled off the back and one of the stats is dented in. The left stat has a red spot, rather than the green one that cherryvale has.
    My serial number is 37660004. Can anyone point me to the right thermo kit?
    Also, my sister has a problem with her Hoover Ultracare condeser dryer. The on/off button is broken. The machine works if you hold in the button, but as soon as you remove the pressure on the button it switches off. Essentially the button won’t click on. Again, can someone point me to a suitable replacement switch?
    Many thanks in advance!
    #190135
    Dave_Conway
    West wrote:My serial number is 37660004. Can anyone point me to the right thermo kit?
    Model number please 🙂
    West wrote:Also, my sister has a problem with her Hoover Ultracare condeser dryer.
    #190136
    West
    Ooops. 😳 Same as above: 37667
    Hmm, don’t have access to it at the moment. Hoover Ultracare Condenser Large Load is on the front. Will find out this evening.
    #190137
    Dave_Conway
    West wrote:Ooops. 😳 Same as above: 37667
    You need 1701557 in that case 🙂
    http://shop.ukwhitegoods.co.uk/product_ … ucts_id=80
