Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP 8242 Dishwasher RESET
- This topic has 19 replies, 10 voices, and was last updated 21 years, 3 months ago by
Ferret.
July 13, 2008 at 7:30 pm #122388
nickjw
ParticipantRe: Diplomat ADP 8242 Dishwasher RESET
The power goes off when I turn
on at the switch on the machine
Can you assist
July 13, 2008 at 7:41 pm #122389Penguin45
That’s a pity…. It means that the mains suppressor and wiring up to the switch is OK and that something internal has gone wrong. Start by checking the wiring through the door – it’s possible that the wiring has broken or chafed at the pivot point, causing a short. Beyond that, any component could have developed a fault – heater, pump, capacitor etc. Can’t really be more specific than that.
Good luck, stay safe, power off if investigating.
July 13, 2008 at 7:56 pm #122390nickjw
Thanks,
I will remove the door and have a look
Nick
July 13, 2008 at 9:01 pm #122391nickjw
I have opened the back
Cannot see anything obvoius although some wires
have come out.
2 are for the mechanism which opens tablet (does this matter whichway they go back ?
2 are for the mechanism which controls circular unit next
to this again the same question ?
Looks like an engineer or new machine as I have
no instruction manuals for wiring
Any advice
December 26, 2008 at 9:18 pm #122392earlond
We had a similar problem. There was a water blockage and on our case the power light would switch on but no other lights would. After reading this forum I tried the trick pressing the power light 4 times and that didn’t work, but this worked:
– Press and hold the program button
– turn off the power button (whilst holding the program button). A program light should turn on then with a bleep, then turn off.
– release the program button, press and hold again whilst the power is off.
– press the power button on. All lights should turn on at the same time then.
– close the door. The machine should start a cycle.
To make sure the water would go down this time I removed and cleaned the filters and put some Mr. Muscle sink unblocker in it. I hope that doesn’t finish destroying the dishwasher though… :rolls: -
