Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP8332
- This topic has 16 replies, 2 voices, and was last updated 18 years, 10 months ago by
ickey.
June 25, 2007 at 10:23 am #28426
ickey
ParticipantHi, i have read through the forums, and have a slightly diferent problem.
The pump will drain at the stat of a programme but will then just make a very quiet humm noise. It doesnt then recirculate any water. No fault codes shown.
Any ideas? ❓
PS – water is in sump as normal, no gunk in filters.
June 25, 2007 at 10:24 am #218331ickey
ParticipantRe: Diplomat ADP8332
Sorry – full model is ADP 8332 🙂
June 25, 2007 at 4:36 pm #218332Penguin45
Two pumps – drain and circulation. Drain pump should stop, water run in, circulation pump should start. Which bit isn’t happening?
June 25, 2007 at 6:22 pm #218333ickey
the circulation bit, it drains ok, then fills, then just humms for a bit and stops……..
June 25, 2007 at 6:34 pm #218334Penguin45
If your machine still has the original circulation pump in it (see this article: http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159 ) you may be in trouble. It could just be jammed by a blockage if you’re lucky.
The new type pump can still be blocked, but may also suffer from failure of the start/run capacitor fitted to it.
Power off if you plan to get underneath it and investigate.
June 25, 2007 at 6:50 pm #218335ickey
thanks for that, will a blockage be fairly obvious to see and easy to clear?
June 25, 2007 at 6:58 pm #218336Penguin45
ickey wrote:thanks for that, will a blockage be fairly obvious to see?
No.
ickey wrote: and easy to clear?
You’ll almost certainly have to pull the pump and split it. Easy on the early pump (twist fit), awkward on the new style one. Be careful to treat the hose clips gently, as they can be very tricky to refit.
June 25, 2007 at 8:38 pm #218337ickey
RIGHT – I have enthusiasticaly taken the bottom off, then got stuck! i take it the pump in question is the big one to the right (looking at the bottom with it on its back facing up) with two hoses coming off it. The hose clips look tamper proof, i.e, i dont know how to get them off!
June 25, 2007 at 8:46 pm #218338Penguin45
Part of the clip will be sticking out looking a bit like a mushroom. Using a flat bladed screwdriver, you need to open the legs of the mushroom. Not by much and they will release the pump. You’ll need to crimp them again on refitting. Which pump unit have you got in there?
June 25, 2007 at 8:50 pm #218339ickey
OK
On the side it says:
ASKOLL
MOD M95
ART 295106
COD 461972474391June 25, 2007 at 8:52 pm #218340Penguin45
Yup, that’s the original one as featured in the article. It will come apart with a twist though, once it’s off.
June 25, 2007 at 8:53 pm #218341ickey
Cheers!
I’ll post back once it get the damn thing out!
June 25, 2007 at 9:08 pm #218342ickey
Well, it,s out, apart and cleaned, just trying to get it back together, i assume it just twists back together – easier said than done! is there a knack or specific way it goes back?
June 25, 2007 at 9:28 pm #218343Penguin45
While the front cover is off – turn the impellor. It should move freely, then resist and go “ping” every quarter turn. If it feels stiff or gratey, it isn’t going to run.
The scallop on the inner housing should line up with the outlet tube for re-assembly.
June 25, 2007 at 9:31 pm #218344ickey
ParticipantIMPELLOR? is that the spindle thing with a magnet around it? If so, the magnet is cracked along it’s entire length?
It spins freely but no click.
