Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat ADP8332 – F4 Fault
- This topic has 23 replies, 11 voices, and was last updated 19 years, 2 months ago by
millyvanilly.
January 23, 2007 at 9:01 pm #24432
millyvanilly
ParticipantI hope someone can help – my dishwasher developed F4 fault yesterday which I gather might be something to do with a blockage or kink in the pipe?? After resetting and trying the cycle again the fault is now showing as FA (think this might be due to too water in there??).
Can someone offer an help for: 1) the orginal fault 2) advice as how to drain the water manually from the machine.
One other thing I should mention is that we have a waste disposal unit that has some shared pipework, and my husband replaced this (waste disposal unit) on Sunday. Coincidence? Probably not.
Can anyone help?January 23, 2007 at 9:36 pm #202049Penguin45
ParticipantRe: Diplomat ADP8332 – F4 Fault
Holding down the button will cancel the programme and should run the drain pump for one minute. If the machine drains into a spigot shared with the macerator, check that it is not still blanked off.
January 24, 2007 at 5:13 pm #202050millyvanilly
Thank you so much for your reply. Your help resolved the problem. Great forum!!
June 4, 2007 at 11:37 am #202051ron1050
My ADP8332 also developed an F4 fault yesterday, It starts its cycle then stops working after 5 or 10 minutes or so and bleeps. Have cleaned out all the filters to no avail – what next – device is only 2 years old by the way
Any asistance would be appreciated.June 4, 2007 at 1:39 pm #202052Simon46
If filter removed is there gunk on the grid at 3 o clock in the sump?
Water level control is here.
S.
June 4, 2007 at 1:49 pm #202053ron1050
I’ll have a look when I get home tonight!
June 5, 2007 at 7:39 am #202054ron1050
The grid is clear..any idea what I should check next?
June 5, 2007 at 7:45 am #202055Simon46
Computer thinks machine is not draining. If start button pressed for 5 secs to reset does the dishwasher empty?
Regards
S.June 5, 2007 at 11:28 am #202056ron1050
Can I ask what do you mean by emptying? – how can I tell if it has water to drain in the first place?
thanx
June 5, 2007 at 11:39 am #202057gegsy
ron1050 wrote:Can I ask what do you mean by emptying? – how can I tell if it has water to drain in the first place?
Normal fill level is just below lower spray arm, half way up its mount.
After the re-set, the appliance pumps out for app 1 min. When the pumping sound ceases, open door and there should be no water above filters in the base only a small amout in sump if you remove filters.Greg
June 8, 2007 at 9:30 am #202058ron1050
The machine appears to drain OK. I had left the machine for a couple of days and some water had accumulated in the bottom by the filter. When I pressed and held the restart button I could hear the water draining away and upon inspection the level had dropped to that described above i.e. just a little bit at the bottom of the filter – so it appears to drain OK. What next?
June 12, 2007 at 7:39 am #202059ron1050
ron1050 wrote:The machine appears to drain OK. I had left the machine for a couple of days and some water had accumulated in the bottom by the filter. When I pressed and held the restart button I could hear the water draining away and upon inspection the level had dropped to that described above i.e. just a little bit at the bottom of the filter – so it appears to drain OK. What next?
Anybody got any more suggestions?
RonJune 12, 2007 at 9:32 pm #202060dpm
ParticipantWater level shouldn’t rise over a few days?
June 14, 2007 at 11:29 am #202061ron1050
Well I got a local engineer to have a look at the machine and his analysis proved quite interesting!
Within a few minutes of me describing the symptoms and he observing them he diagnosed a split hose on the main wash pump. He knew this without even inspecting the machine because every single person that had this machine had experienced the same problem!. Sure enough when he got the pump out there was a split about 2 ” long around the rubber hose (explains why water was going where it shouldn’t!).
Furthermore, he claims it’s a “known” design fault as the hose is not manufactured to a high enough spec and can’t handle the load put on it. He claimed that Whirlpool are fully aware of this problem but are chossing not to do anything about their manufacturing process!
He reckoned the part would be around £150 ( the hose cannot just be detached and replaced because it is an integral part of the pump) but recommended I complain direct to Whirlpool on the grounds of “not fit for purpose”.
I will let you know how I get on.
June 14, 2007 at 7:04 pm #202062Penguin45
Ah……..
Read and enjoy:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=159Penguin45.
