Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Diplomat oven not working
- This topic has 16 replies, 4 voices, and was last updated 11 years, 4 months ago by
Bas400.
November 17, 2014 at 7:29 pm #83059
Bas400
ParticipantI’m having a problem with my diplomat 620 oven I have renewed the element and the selector switch. But still not working could it be the thermostat.
November 17, 2014 at 7:44 pm #421588SAMURI
ParticipantRe: Diplomat oven not working
I would need the model number to advise normaly starts with an A and 2 other letters then 4 numbers.
If your model has an electronic timer you need to have a time set on the clock for the oven to work.
Check to see if you have a time set any time will do it does not have to be the correct time.
Bob
November 17, 2014 at 8:03 pm #421589Bas400
Not sure of model number looked inside the door but nothing there. On the front it says SELECT 620 by DIPLOMAT. The clock is set to correct time as wellThanks
BrianNovember 17, 2014 at 8:42 pm #421590Bas400
Hi Bob
I have found the Model number on the back of the oven AHY3620
ThanksNovember 17, 2014 at 9:11 pm #421591adv
what was wrong with oven in first place ? was it just dead or not heating ?
November 17, 2014 at 9:20 pm #421592SAMURI
It will most likely be the oven safety cut out stat at the back of the oven.
It is like a small round button size stat with 2 wires going to it.
Check to see if it is open circuit if it is you will need to replace it.
For test purposes only you can join the 2 wires together to see if the oven works.
If it does then fit a new stat. Do not use the oven with the wires together as it is a safety device to prevent overheating.
Bob
November 17, 2014 at 10:43 pm #421593Bas400
Hi Bob
I’ve tried joining the wires together but still nothingNovember 18, 2014 at 8:00 am #421594SAMURI
Try joining the 2 wires to the main thermostat to bypass the main thermostat.
Did you check the round button size stat for continuity at the same time
BobNovember 18, 2014 at 8:06 am #421595SAMURI
If it is not the safety thermostat TOC or the main stat and a time is set on the timer then it is most likely a timer fault.
The timers a not cheap.
Bob
November 18, 2014 at 10:07 am #421596Bas400
Hi Bob
There is another stat like the one I tried on the back It is situated on the top just behind the clock also with two wires attachedWould i be better to change the thermostat out first? Is there anyway i can test the timer or bypass it altogether
BrianNovember 18, 2014 at 10:11 am #421597adv
that state could be for the cooling fan if it has one , only activates when oven gets hot
November 18, 2014 at 11:12 am #421598Bas400
Yes it has a cooling fan at the back of the oven
November 18, 2014 at 12:49 pm #421599Bas400
I will try joining the 2 wires to the main thermostat to bypass the main thermostat tonight.
I have located the round button size stat and joined the wires together.Not sure what this means Bob for CONTINUITY at the same time
November 18, 2014 at 2:25 pm #421600SAMURI
If you joined the wires on the button stat and it did not make any difference the stat may be ok.
To test the stat you just need to check if you have a circuit through it the same as you can check a fuse.
Bob
November 18, 2014 at 7:18 pm #421601Bas400
Thanks for your help bob
But no joy think I’m going to give up .
Cheers
Brian -
