Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Dishwasher heater control
- This topic has 31 replies, 5 voices, and was last updated 9 years ago by
Pwcomp.
March 28, 2017 at 11:40 am #446363
ModeratorRe: Dishwasher heater control
that’s the power supply and that’s ok so
March 28, 2017 at 12:14 pm #446364Martin
ParticipantRe: Dishwasher heater control
A decent photo of the whole board (solder side) would be nice 😀
March 28, 2017 at 12:24 pm #446365Pwcomp
Looks ok to me. But am starting to run out of things to check really. Thanks as always for advice.
March 28, 2017 at 2:42 pm #446366Martin
Yeah that board looks OK.
Another possibility? Partial main circulating pump blockage allowing the heater safety flow switch to operate leading to a ‘time out’ problem. Therefore check for plenty of spray pressure flow through each spray arm once it has filled. (Test that during a pre-soak cycle).
March 28, 2017 at 6:14 pm #446367timdowning
In fact run a cycle or two with the spray arms completely off
March 28, 2017 at 9:03 pm #446368Pwcomp
Thanks guys I’ll try that next. in the morning. Fed up washing by hand Now.
March 29, 2017 at 10:30 am #446369Pwcomp
Ran the machine pressure seems fine as also ran it with no arms fitted. Still sits on the 1 point and runs for ever at that stage. Unless someone has a brainstorm of an idea. It’s either the bin or get an engineer in. Any one know of a cheap engineer in the Fareham Hampshire area? Hate being beaten by a machine. 😥
March 29, 2017 at 10:38 am #446370electrofix
you don’t want a cheap engineer you want a good engineer to do good job at a reasonable price
try
http://www.ukwhitegoods.co.uk/search/fi … e-engineerDave
March 30, 2017 at 5:26 pm #446371Pwcomp
Thanks for that Dave. Not sure which way to go now bit frustrated we with it. Thanks for your reply.
Paul
March 31, 2017 at 7:13 am #446372Martin
So just to clarify, if you set your machine to do just the Pre-soak program it still shows 1 minute at the end does it?
March 31, 2017 at 9:30 am #446373Pwcomp
Forgot to try that. Just ran it and it does indeed stop on prewash. Only keeps running on the main programme. Hope this means something thanks again for all your help. Paul.
March 31, 2017 at 10:19 am #446374Martin
Then the problem is clearly heat related. So, we’ve established that is does heat (i.e. Gets hot and steamy, enough to steam your glasses anyway). So it could indicated it ‘overheats’ due to a faulty thermostat OR the drain pump gets sluggish trying to empty the very hot water at the end of the final rinse.
Now, I believe you have confirmed that when it stops with 1 min showing it has in fact fully emptied. So that rules out the drain pump though, in my experience, that is the more likely component to fail rather than the thermostat. There is a third possibility in that the plug in connection to the thermostat (sits atop the heater unit) may be loose?
I hope that may help you? 😀
March 31, 2017 at 10:43 am #446375Pwcomp
just to clarify on prewash it goes to 0 and stops, its on the full wash it keeps running and showing 1?hope that makes sense? drain pump is brand new as well/
thanks again.
March 31, 2017 at 4:59 pm #446376Pwcomp
Martin am I right in that the thermostat is called a NTC unit? Or is that some thing else. Just looking at prices. Cheers. Paul
March 31, 2017 at 5:12 pm #446377Martin
Pwcomp wrote:Martin am I right in that the thermostat is called a NTC unit?
Yes Paul it is in Bosch speak a ‘Sensor-NTC’ and the actual part number is 00165281 £21.11(incl P&P)
