Re: Do you repair Induction hobs?
You can fit one above an oven but make sure you follow the install instructions on venting and insulation.
One more thing to consider if you are thinking about buying one, is that they usually “power share”.
That is they will usually only allow you to operate two plates on “full power” while limiting the other two to “half power” if you try and use more than two on full power at any one time.
This is’nt usually a problem tho’ as it’s unlikely you’ll need more than two on full power at any one time!
Great pieces of kit! (if you can afford them!)
