Double or single electric oven?
Home Forums Public Support Forums General Enquiries And Questions Double or single electric oven?
Viewing 15 posts - 1 through 15 (of 22 total)
  • #72497
    JesseConant
    Hi guys,
    I’m considering getting an electric range with a double oven vs. a single electric oven?
    I live alone and don’t do a lot of complicated cooking. I thought it might be a good idea to get the double oven because much of what I would do could be done in the smaller portion of the oven.
    Any opinion on this would be appreciated.
    Jesse
    #384659
    captaincaveman1
    Re: Double or single electric oven?
    JesseConant wrote:Hi guys,
    Jesse
    Single ovens (pyrolytic excluded) plug into a normal 13 amp socket however a double oven must only be fitted on the 30amp cooker circuit so check where your siting it otherwise you have the exspence of an electrician to consider if you go for a double oven .
    #384660
    JesseConant
    captaincaveman1 wrote:
    JesseConant wrote:
    Hi guys,
    Jesse
    Hi captaincaveman1,
    Oh the circuit matters,thanks for reminder.Otherwise I am to have extra expense for reinstall.
    #384661
    DrDill
    Again, some one is incorrect, you can get a pyro oven that plugs in, you can even get a 90cm wide dual fual range that works on 13amps.
    Captain caveman, i think you need to end your advice with “as far as i know” as you are not fully correct in some of your advice.
    Sent from my iPhone
    http://www.kitchenkitsw.com
    #384662
    DrDill wrote:Again, some one is incorrect, you can get a pyro oven that plugs in, you can even get a 90cm wide dual fual range that works on 13amps.
    Really? Can you give us an example Doc?
    #384663
    don
    Hi Martin
    It must be a single cavity dual fuel range like the Indesit K9F11SKG or the Flavel FDF90 to run off a 13A socket.
    Don
    #384664
    DrDill
    Martin, i do a list as there is many models. I have said this so that the op can get more choice, and not be limited by missinformation
    Sent from my iPhone
    #384665
    DrDill wrote:Martin, i do a list as there is many models.
    Do please just give me one example of a pyrolytic oven that can run off a 13 amp plug….please? 🙂
    #384666
    keepitsimple
    Hello, Jesse
    Can only speak as an end-user rather than an expert.
    I went through the same decisions a couple of years ago when I refitted my kitchen. I finally decided on a single cavity built under oven. Main reason was I couldn’t find (at that time) a double oven with pyrolitic cleaning (which I particularly wanted – hate oven cleaning). Also, the one I bought seems to have extremely good insulation, including triple glazed door etc. and I’m guessing it is as cheap to run as many smaller cavity ovens. Heats up very quickly too. The downside is the grill is in the top of the oven of course, which could be limiting if you needed to use both at the same time. (I find a cast iron skillet better for most “grilling” anyway).
    #384667
    Martin wrote:Do please just give me one example of a pyrolytic oven that can run off a 13 amp plug….please? 🙂
    I’ve since checked the installation spec on several single pyrolytic ovens and the lowest consumption is 16amps. So, far from being adaptable to plug into a 13amp socket. But my question still stands to try to prove Captaincaveman wrong is his statement. 😉
    #384668
    DrDill
    For you martin, the manufacturer states 13amp power supply:-
    Smeg SCP115X
    Smeg SCP399X-8
    Smeg SCP496n-8
    I could go on with other manufacturers, but i wont.
    Your appology would be most welcolm Martin
    Sent from my iPhone
    #384669
    DrDill wrote:For you martin, the manufacturer states 13amp power supply
    How very interesting, thank you for that, something new that I’ve learnt already today. 🙂
    #384670
    DrDill
    Is it too much for you too apologise?
    Sent from my iPhone
    #384671
    DrDill
    And too add the customer could have a 4 zone induction hob that also plugs in, even having the plug top fitted!
    Sent from my iPhone
    #384672
    captaincaveman1
    :rolls: Give yourself a pat on the back Dr Dill but the fact is most pyro ovens are above 15 amps so I was merely making the op aware of that and now I suspect you will of confused them To the point they may think any pyro oven just plugs in a socket
