dv06 dryer
Viewing 12 posts - 16 through 27 (of 27 total)
  • #384152
    timdowning
    Re: dv06 dryer
    Strange thing is its been working fine for 3 months on low heat. (I said I’ve been meaning to post about it. Luckily they haven’t been chasing it up).
    And only 2 months before this cutting out fault I cleaned it all out whilst replacing the rear bearing on it.
    Just for good luck i cleaned it out again.
    #384153
    Re: dv06 dryer
    Dunno Tim I can only tell you what it’s doing, not always why it’s doing it and that’s the safety shutdown for an overheat that can only be tripped by the stats.
    timdowning
    Re: dv06 dryer
    Fair point. Thanks for the replies, especially as it’s a Sunday!!
    #384155
    nigegt
    Re: dv06 dryer
    Does the filter open out on this model? I had a CD60w that wasn’t drying well or condensing. The customer had only ever wiped fluff off the outside of the filter.(Didn’t know it clipped open) When opened up the filter wasn’t full of fluff but the gauze was just choked and after a wash with a stiff scrubber all was well again. (It took 3 years to get like this mind!)
    Nige
    #384156
    Re: dv06 dryer
    Yes Nige, they all have the double lint filter.
    deltra
    Re: dv06 dryer
    Sorted!!!!!! Fitted new heater stats, quickly tested 150 stat,( boil pan) it seemed to trip at 60, hope that’s it !
    #384158
    deltra
    Re: dv06 dryer
    bloody hell,the things gone t{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}£$ up again. put it on DRY cycle, runs for 2 mins then trips overheat stat.(dead) run it on NORMAL DRY cycle,works great, why oh why!!!! no blockages at all, even had a new lint filter. everything seems ok,(new heater and 2 stats and exhaust stat fitted month ago!!!) any ideas? customer not happy.
    #384159
    Re: dv06 dryer
    Where’s this installed David?
    deltra
    Re: dv06 dryer
    hi ken, its in a large,warm,well vented utility room
    #384161
    timdowning
    Re: dv06 dryer
    Does K mean in a kitchen, cupboard, outhouse etc?
    #384162
    Re: dv06 dryer
    Well, I can’t think of any reason then.
    If there’s adequate ventilation and it’s not cold there’s no reason for popping stats other than they’re opening it before it’s run through the cool down phase.
    deltra
    Re: dv06 dryer
    went again today, ran ok twice now!! hope thats it.(still trips after 2 mins on DRY cycle????)
