Ecover & low temp washes.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ecover & low temp washes.
Viewing 31 post (of 31 total)
  • #259124
    Re: Ecover & low temp washes.
    As promised…….:D
    Aquados wrote:Hi Martin,
    We have tested our retained sample from the batch number given. We use a miele washing machine for our laundry testing as this particularly make has a low water usage which enables us to see the disssolving effeciency of our product. We select the 30c temperature as this is the desired temperature to be eco friendly.We also dissolve the tabs in a container at different temperatures to see the effect and this has shown the the tabs will dissolve in cold water.
    The results from the batch number given were good. The tabs had completely dissolved and no residues were left in the washing machine drum.
    If you would like to try the product again I will send you a replacement tub of the Simply Sensitive that we are producing at this moment to see if you have a better result.
    Kind Regards
    Julie Thompson Customer Services
