Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › electra awm1100b eco has power/water but does nothing
- This topic has 25 replies, 6 voices, and was last updated 16 years, 11 months ago by
sparkes81.
April 19, 2009 at 3:48 pm #283335
sparkes81
ParticipantRe: electra awm1100b eco has power/water but does nothing
ok removed a leg of one of the resistors from the board but could not get a reading across it.
my mutimeter display does not change when applied
just in case i checked if my meter was ok to check this ohm range and it said it could test Resistance at 20Mž ±0.8{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}.
April 19, 2009 at 3:59 pm #283336Specialist01269
O.K your meter is more than capable of measuring these resistors, if you take the resistor out completely & take it to your nearest Maplin store you should be able to get a replacement no problem. Make sure you check the other 1 just in case but it’s usually only 1 goes o/c. It may be an idea to get 2 incase it happens again in the future. 8)
Andy
April 19, 2009 at 4:20 pm #283337sparkes81
ParticipantApril 19, 2009 at 4:57 pm #283338Specialist01269
Hi the sleeves are for insulation to stop the legs of the resistor from shorting out to the components around it, theyr’e also heatproof because these resistors run quite warm.
The replacements won’t have this on them so you need to transfer it over,
they will also possibly be slightly larger but will fit comfortably.Andy 🙂
April 21, 2009 at 10:25 am #283339sparkes81
hi sorry to be a pain but im having trouble locating the correct replacement resistors.
i cant find them on either the maplin or the RS websites!
am i searching for the wrong thing? lol
it says on the resistor: 6.2KΩ J 5W
but alas i cant find an equivalent!
April 21, 2009 at 2:30 pm #283340gandh1
I’m keen to find out if this works as it would be muchly appreciated if specialist can then explain the logic as to why he picked out the ceramic resistors.
April 21, 2009 at 3:20 pm #283341timdowning
You might get lucky with this selection:
April 22, 2009 at 4:17 pm #283342Specialist01269
gandh1 wrote:I’m keen to find out if this works as it would be muchly appreciated if specialist can then explain the logic as to why he picked out the ceramic resistors.
I didn’t actually, but these resistors going & causing this fault is not a new thing it’s been reported in the past by other engineers.
From a personal point of view I allways check high value resistors i.e 100k & over, Wirewound resistors & Electrolytic capacitors before replacing any board, it’s surprising over the years how many times this has paid off & saved a replacement board, it’s something I was taught to do when studying Electronic servicing many moons ago.
April 22, 2009 at 4:52 pm #283343Specialist01269
sparkes81 wrote:hi sorry to be a pain but im having trouble locating the correct replacement resistors.
Hi: Tried several places to source these for you but the closest commonly available value is 6K8 either 5 or 7 watt, you could try 1 in place of the blown resistor, it won’t cause any damage if it doesn’t work. Or try your local TV repair shop, they may have some old stock lying about.
Personally I’d get a 6K8 7 watt & try it.
Andy.April 23, 2009 at 11:05 am #283344sparkes81
hi i think ive found the correct resistor at RS electronics.
http://uk.rs-online.com/web/search/sear … &R=1997882
can you just confirm this for me before i buy :0)
thanks.
April 23, 2009 at 2:27 pm #283345Specialist01269
Hi Mate: O.K right value & wattage but you need Axial leaded not Radial leaded, i.e with the leads comin out of either end rather than both coming out of the bottom end.
The web address you need is: http://www.cpc.co.ukPart No: RE 03462
Value: 6K8 7 watt
Type: Axial Wirewound.
Price: £1.73 for a pack of 5 inclusive of VAT but carriage is extra.
Hope that helps: Andy 8)
