Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Electrolux Dishwasher strange problem
- This topic has 17 replies, 3 voices, and was last updated 3 years, 11 months ago by
gman41.
April 21, 2022 at 4:25 pm #100756
gman41
ParticipantHi Everyone,
We have a Electrolux dishwasher ESL5205LO
No fault codes and we have had an engineer out to look at it confirmed everything working, BUT every cycle used to end in a big Steam cloud as the door opened at the end of every cycle, now no steam???
The engineer check the pump was working, the element is working, and looked in the engineer secret menu to see if any fault codes have been logged, and nothing!
All it does no matter which cycle we use is finish with no stream at the end and a poor cleaning finish.
Have cleaned all filters too.If you have any idea why this has happened of give any tips, would love to hear from you!
April 23, 2022 at 4:27 pm #482081tubafan
ParticipantIs it definitely getting hot during the wash cycle as this sounds like the heating element isn’t working (despite what the engineer says)?
April 23, 2022 at 4:40 pm #482082electrofix
Moderatormaybe an intermittant heater fault
heater failure on a lot of dishwashers does not bring up a fault code but it does extend the programmes as it waits for heat then aborts heating phase
April 23, 2022 at 4:41 pm #482083gman41
ParticipantHi Tubafan,
The engineer was happy the element was working, he checked the amps it was drawing via multi meter, It gets warm in the cycle, some steam can be seen, but not like the end cycle when the door opens, still nothing, have tried the reset option, but nothing…no different.
No error codes…just cant understand the disappearance of the steam at final stage???April 23, 2022 at 4:49 pm #482084gman41
ParticipantCheers Dave, will investigate that!!!
April 23, 2022 at 4:54 pm #482085gman41
ParticipantAlso Dave there is no extra time for the extend the programmes, all cycles are spot on!
April 23, 2022 at 4:56 pm #482086electrofix
Moderatorlet me have the PNC number off the label and i can see if there is anything specific to this fault listed
should be 9 digits plus 2 more
April 23, 2022 at 7:02 pm #482087gman41
ParticipantThanks Dave, I think this is correct Product number 91153921500
April 23, 2022 at 7:31 pm #482088gman41
ParticipantJust done a intense wash and as door opened the dish washer was cold, always piping hot as the door opened!
April 23, 2022 at 8:38 pm #482089electrofix
Moderatorcheck if you have the air dry option on or off
April 24, 2022 at 8:44 am #482090gman41
ParticipantHi Dave, The Airdry is automatically on with all cycles, so will try it off and see what the results are…
June 25, 2022 at 2:55 pm #482091gman41
ParticipantUpdate…
We paid Electrolux a one off payment to get it fixed a eye watering £141.
3 engineers came over 5 visits heating element changed and still the same results, but just give up with them and trying to get our money back.
Anyway…on the 30 minute cycle we DO have steam and heat, just not on the normal cycle of intensive, they are COLD.
Has anyone came across this?
Its looking towards the PCB board…but that’s my guessAnyone got any ideas???
June 25, 2022 at 5:46 pm #482092electrofix
Moderatorare you still getting heat on some programmes but not others because it sounds like a motor tacho failure which stops it heating
June 26, 2022 at 7:36 am #482093gman41
ParticipantHi Dave, I have heat and steam on the 30 min wash, its currently on the normal wash 65 temp… and checked it mid cycle and cold!
June 26, 2022 at 8:38 am #482094electrofix
Moderatortry something
try a 65 temp wash. wait till it opens the detergent container ( this proves it should be heating) then leave it 10 mins to be sure heater has not energised.
Then cancel the programme and restart immediatly on a 30 min washThen check if it heats
