Fault E30 Zanussi Washing Machine Model ZWG1120M
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Fault E30 Zanussi Washing Machine Model ZWG1120M
Viewing 15 posts - 1 through 15 (of 17 total)
  • #97995
    R0y1949
    Zanussi Washing Machine E30 Fault displaying when trying to use machine. Any help appreciated.
    #470489
    A door lock fault, is the latch faulty or door not closed properly. Could also be the doorlock itself at fault.
    #470490
    R0y1949
    Door lock working fine you can hear the lock engage.
    #470491
    well E30 as Iadom says is a door lock fault
    that means the board fails to get a door locked signal so it could be
    faulty door lock
    faulty wire between door lock and board
    faulty board
    R0y1949
    Thankyou for your replays looked up this falt they said air pump connected to drain pump
    #470493
    thats a new one on me
    look inside the door and get me the full Pnc number off the label
    R0y1949
    Prod no 9145765609 typetg80-12601e/1tel ser no 14565609 espairs said blocked drain hose
    #470495
    do you want to recheck that pnc
    based on your model no i get 7 machines but the pnc does not match any of them
    R0y1949
    #470497
    in that ccase the list of fault codes for your machine are
    R0y1949
    Thankyou i can feel and HEAR DOOR CLICKING the locks wait for 1 minute and door opens
    #470499
    R0y1949
    Dave can the door lock and still be faulty
    #470500
    the door lock closes and the output wire should then become either live or neutral depending on how its wired ( normally live) this live is fed back to the board so it knows if its locked
    so as said above you faults can be
    faulty door lock
    faulty board
    just as a very long shot check the motor brushes. prob wrong as its got a fault code but some machines do something similar if the brushes fail
    #470501
    R0y1949
    Dave i fitted new brushes it sat for a week brought in water drum turned and e 30 falt
    #470502
    so E30 fault happended just after new brushes
    double check things as a long shot
    see if anything changes if you unplug motor
