fisher +paykel
Viewing 15 posts - 1 through 15 (of 22 total)
  • #31482
    machineman
    what am i doing wrong.changed heater, door wont close ,old plastic hose support snapped ,put new metal one in ,door still wont close .ps lid is open .what am i missing beside a brain.m
    #231291
    cab
    Re: fisher +paykel
    have you had the drawers out, if so are they all the way back on the runners till they click?
    cab
    #231292
    machineman
    tried that ,when you click the slides in place the back of the drawer is anchored to the slide.m
    #231293
    johnmac11
    Re: fisher +paykel
    Usualy one of two problems cause this.
    The most likely problem is that when fitting the element you turned the basket upside down by turning it anticlockwise. After fitting the element you turned the basket back over still going anticlockwise which kinks the hoses ( making the link support to snap ) and causes this problem. When you turn these drawers upside down you always return them in the opposite direction.
    The other problem could be that the white plastic drawer catches at the back of the runner in the closed position.
    John
    #231294
    machineman
    good point.so why wont it shut after fitting new arm and the drawer catches are open,have i twisted the hoses,how should they run.m
    #231295
    realengineer
    Re: fisher +paykel
    sorrie as the F&P engineer for manchester area’s i think you
    made a mistake
    1. are the hoses in the right order water/electric/drainhose
    look ad the other drawer to make sure they in the same place
    2. on the back of the drawers there are 2 lockers
    are they both unlocked
    3 !!! u didnt leave any tools inside !!! easy done
    good luck
    #231296
    johnmac11
    Re: fisher +paykel
    If you turned the drawer the wrong way you probably wont see any difference in the hoses. Easy way to find out is to take the drawer out and turn it 360 deg anticlockwise, put it back in and see if it works. If it doesnt put it back the way it was and then turn it 360 clockwise and try again.
    John
    #231297
    machineman
    surely its water/drain/electrics.m
    #231298
    realengineer
    Re: fisher +paykel
    no no
    electric in middle
    i think !!!!!
    #231299
    EFS
    Re: fisher +paykel
    If you have the double drawer model you may as well change the cable tidy for the new metal version on the other drawer because it will break in time anyway.
    When you have done that you can look at it and you should be able to see where you went wrong with the other drawer.
    There is one right way to lay the pipes and that is it!
    I defy anyone to explain it in words how it should be done.
    Steve
    #231300
    realengineer
    Re: fisher +paykel
    I second that
    even as a belgium
    u should give me a contact number tomorrow saturday i go to
    a job and can tell you preciese how it done
    remember take a picture b4 doing anything
    u must have a camera on mobile
    then do it in reverse order
    and if that doesnt help ring F&P
    there always a good engineer around
    I love fisher and paykel
    #231301
    realengineer
    Re: fisher +paykel
    sorrie steve
    am not so well on words
    but i will do the job
    just a belgium u know
    #231302
    machineman
    its a single drawer.m
    #231303
    EFS
    Re: fisher +paykel
    cookermann wrote:I second that
    even as a belgium
    Yes but then you put mayonnaise on your chips 😯
    Steve
    #231304
    Re: fisher +paykel
    Oi! One of lifes little luxuries – I put mayonaise on chips…..
