Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › F&P GW709AU
- This topic has 28 replies, 8 voices, and was last updated 20 years, 8 months ago by
admin.
January 15, 2006 at 12:01 am #143644
sclarke7171
ParticipantRe: F&P GW709AU
Hi again,
Checked it this morning and the Cold Valve is open circuit.
When i check the voltages there is no power at all to either coil.
Machine starts and starts to move the drum, then stops then starts, then stops. at no time on a normal cycle can i get the 24V at the soleniod coils for the Hot or cold water.
Then after some short time 5 mins? it gives the 00110010 error and in diag gives the same error.
Please Help.
ohh what should the PN be for the Cold Solenoid.
to change them is the easiest way solder it back on the board or splice the wires??
Thank you all once again.Steve
January 15, 2006 at 12:40 am #143645Penguin45
Fault code 50 – specifically a Hot valve fault. Secondary fault can be cold valve, but this is almost always a motor controller board as well……
Cold valve – 420148
Hot valve – 420147Keep it on one thread please – there’s only three of us who can answer the problem and we do manage to keep up 😀 .
Penguin45.January 15, 2006 at 1:59 am #143646sclarke7171
Thanks for the reply.
So what parts should i order?
part numbers please.is the controller board the board behind the front panel or is it further down near the motor??
Thank you so much for your help.
Steve
January 15, 2006 at 9:02 pm #143647Penguin45
P/nos in my last post. If you don’t have a reading of 62 ohms on the cold valve, it’s faulty and needs to be replaced at least. Splicing/soldering wires should not be neccessary, simply remove the connector and refit.
The motor board is the lower one of the two boards in the console panel. Do the valve first, it’s a damn site cheaper the the board.
Penguin45.January 16, 2006 at 2:43 am #143648sclarke7171
Ok.
Thanks for the Valve part numbers.so there is a connector on the solenoid? i did not see it, but mind you i did not look hard.
the board your talking about.
when i take the front top panel off that contains the push button membrane assembly there is one held in with 1 screw that the solenoid wires go to and it also has the power in (240v), about 5 connectors and the pressude transducer? Is this it. The board is in a grey plastic wedge shapped case that you can unclip to get open.
The GW709 is about 8 years old i think.Is that the right one??
Thank you again.
January 16, 2006 at 2:56 am #143649sclarke7171
I just found the parts manual for this as well.
http://www.stokes-aus.com.au/StokesAP/info_sheets_fp_Washing_Machines_Dryers.asp
Hope this can help some more of the guys who need parts
February 14, 2006 at 10:51 pm #143650FastAndPro
For future referance on this one when it comes up with a hot valve fault and the cold is open circuit or leaking it normally has taken the motor control board with it Replace the cold valve before replaceing module
June 14, 2006 at 10:46 pm #143651fringe
Hi all,
thankyou for providing this forum !Firstly if is possible could someone email me the fault code index for Gw709au,
also a detailed instruction on how to reset the machine after a board change. 7.5kg ExcellenceFirstly i developed a fault code 01100010 right hand side 0 being the spin light,
after reading all the forum post relating to this machine, i checked both the cold and hot water valve for an open cct, however none were
cold water was 64 ohms hot water was 41 ohms, so i purchased a hot water valve new it measured 62 ohms, however the fault still existed
after following a few other proceedures that have been described i have had that fault code go away and another develop this time it is 01000001 right hand side 0 being the spin light, i am having the whole motor controller board replaced today as we need it working, but i have asked the wife to make sure he leaves the old board, i have the skills to hunt the the faulty cap or ic but as you know you do it the hard way or with some assistance.
by knowing the fault codes and how to reset the board to operation for this model i can check that i have fix the problem by swapping the old board in and out
will post results for others to fix this expensive item
email codes and reset to: mkilburn@kooee.com.au if possible.if i have attacked this machine wrong please let me know
kind Regards
MarkJune 15, 2006 at 12:19 am #143652Penguin45
Both codes which you have posted relate to the water level control switch, which is an integral part of the motor board, so replacement was probably the correct course of action.
I regret that we cannot publish the entire list of codes – the information is copyright to F+P; although we can answer specific questions without them jumping on us!
Tech info on the level switch is extremely non-specific. It says the switch can control the water to any level – this would suggest that it works on a transducer principle, or a moving magnet/coil system. Consequently, part of the control board will be geared to interpreting the info; usually some sort of comparator array. The variable output of the switch will be compared against fixed values to provide the level control.
HTH,
Penguin45.June 15, 2006 at 1:25 am #143653fringe
Thanks Penguin,
The information you provided is spot on, i failed to mention that initially the machine wouldn’t empty; straight away i attended to the water level mech.
Firstly blowing through the tubes, secondly i pulled out the controlled board and dismantled the water level mech (which in this model is a moving coil) there was no problem with the coils or the diaphragm.
so thats when i found your site, iwas led to the hot and cold valves through some posts, in a way i am glad as the hot soleniod was already bubbled as showing signs of immenant failure,So based on the fault code indicates that it is to do with the water level i suspect that the surface mount caps or comparator network are at fault. I will change all associated capacitors first, and let you know the out come.
however, is there a reset proceedure for setting this board to default and then programming it to 7.5kg?
Regards
MarkJune 15, 2006 at 10:24 am #143654fringe
Hi all,
I was able to take a look at the water level indicator today.
As has been previously mentioned it is a moving coil. The basic operation is that when positive pressure is applied to the diaphragm by the water level raising within the tube connected to the water sensor unit, it moves the ferrite bead located internally. Which turn changes they inductance of the coil. However, it is not change in voltage the microprocessor is looking for. It is actually a change in the oscillator frequency as the ferrite bead moves up or down the frequency will increase or decrease accordinglyBefore going into the micro it square up by a 78C04 producing a square wave proportional to the input freq
The change in frequency is the applied to micro and compared to its reference oscillator frequency
However, when I measured the original timing capacitor it measured 225nf
The measured frequency at that time from the water level circuit ranged from 72 kHz to 83 kHz
Changing this capacitor to 220nf changed the output frequency.The measured frequency now from the water level circuit ranges from 68 kHz to 79 kHz
Well this is where I am at, at present F&P can’t come until Wednesday so I don’t have another board I can check the correct values.
For all I know the value could have been 330nf and because of error in current value the processor see the resulted frequency to be out side it range it shut it all down.
So can someone measure the capacitor and post its value.
The timing cap is located bottom far right hand side with the board facing down, first cap in from the edge nearest the coil.Ps since changing this cap to 220nf I receive a new fault code 00001011
Which I bet is water level related, further more the machine seems to be trying harder to get going so I believe i am near the frequency rangePlease checks the info provided and correct me if I am wrong.
just another thought if you have a cro just measure the frequency on the legs of the coil when empty and full if you cant measure the cap or post both
Kind regards
Mark
Ps sorry the post was so longJune 15, 2006 at 10:35 am #143655fringe
Just found some who had posted the same for a IW709
sorry if i double up!
any his post is under topic IW709 Fills up then Error 39
he belives it is a .1uf
i will try this tommorrowregards mark
June 15, 2006 at 11:17 am #143656aargee
Fringe,
Be aware that the control board for the GW and IW series appears to be different. The capacitor I found open circuit on our IW709 had no effect on the frequency of the fill circuit, it was there to decouple the clock from the microprocessor. Ours was open circuit, so no fill clock. I replaced it with a 0.1uF (a guess, as the original was not marked) and it is working to this day. (Experimenting with different values had no effect on the fill clock frequency).
As far as I can see, if you are getting a pulse train at the uP pin that varies with air pressure, then the fill circuit is working.
Good Luck.
-Rob.
June 15, 2006 at 7:21 pm #143657Penguin45
Size setting on this machine is as follows:
Hold “Temp up”, press “Power”.
Wait for 4 short beeps.
Press “Spin speed up” for 7kg machine – “Spin hold” LED should light.
Power off.00001011 is a pressure sensor fault……………… 😀 . It’s detecting negative pressure – can be caused by connecting the air pressure hose before the drum is fully empty (partial vacuum created by water level falling). Alternately, the motor board is at fault.
Penguin45. -
