Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Fridge / Freezer
- This topic has 15 replies, 5 voices, and was last updated 18 years, 3 months ago by
johnuk.
December 26, 2007 at 6:44 am #33232
johnuk
ParticipantHi I have a zanussi frost free Fridge Freezer that is working perfectly
but it constantly makes a clicking noise , would anyone know what this noise
is , and is it normalThankyou in advance
merry xmasDecember 26, 2007 at 3:25 pm #237907Penguin45
ParticipantRe: Fridge / Freezer
Model number please, John.
December 26, 2007 at 10:41 pm #237908johnuk
Hi Mate I have searched high and low for a serial number cant find it
just to add , the bloody thing stopped again the fridge bit was warm so I removed the panel inside the freezer and exposed the radiator which was covered in ice thawed it out using a hair drier now the fridge is cold again have checked since and it has started to ice up again , is this serious can an engineer repair or should i replace
thankyou for your replyDecember 26, 2007 at 11:18 pm #237909kwatt
KeymasterWithout the model number so we can see what it is it’s nigh on impossible to say. 😕
It could be as simple as a duff thermistor or heater, which is likely, to something more sinister.
December 27, 2007 at 5:41 am #237910johnuk
ok I will hunt for the serial number today I presume its round the back somewhere , thankyou again for all ur help
December 27, 2007 at 6:35 am #237911Simon46
Look near the salad bins on the inside wall of the fridge
Regards
S.December 27, 2007 at 2:52 pm #237912johnuk
Model Number is ZX56/4W
Thankyou all
p.s I have turned it down from 4 to 3 will that help
temp is btween 4 and 5December 28, 2007 at 6:36 pm #237913BROKENMAN
hi is the noise like a clock if so maybe a noisy defrost timer
December 28, 2007 at 7:52 pm #237914johnuk
yeh it is kind of like a clock
would that be the cause of the problem
is that why the fridge after a few days begins to get warmDecember 31, 2007 at 5:44 am #237915johnuk
I have been told that the reason the radiator gets iced up is because of faulty defrost imes , does that sound correct
December 31, 2007 at 12:05 pm #237916kwatt
KeymasterRe: Fridge / Freezer
Hi John,
It’s all too likely that the defrost timer is the problem as they do fail and the defrost cycle doesn’t happen. It’s certainly the running favorite for being the culprit.
Defrost timer is here if you need one.
December 31, 2007 at 4:24 pm #237917johnuk
Thankyou so much for your help
I last thing it looks quite easy to fit , but where is it
thankyou againDecember 31, 2007 at 5:17 pm #237918kwatt
KeymasterIIRC the back right hand side.
January 1, 2008 at 9:00 am #237919johnuk
Sorry , is that behind the panel in the freezer , is it easy to fit is there any soldering etc Thanku again for all ur help
January 1, 2008 at 12:15 pm #237920kwatt
KeymasterYou should see it in a housing on the rear, again totally from memory as it’s a while since I’ve seen one and it’s just fitted with spade connectors.
