Re: Gas tumble dryer
Thanks Kwatt,
What a brilliant bunch of folk you all are.
So it seems ‘keep it simple’ on all accounts is the conclusion I’m coming to:
– Forget the expensive lower running cost versions if using the machine Ad Hoc for domestic.
-Best option is therefore a cheaper long standing workhorse of an electric model. White Knight or Beko
-Position the machine up high in the cellar to avoid a vertical vent (as much as possible).
-Drain the vent and clean it out regularly.
-Use the box condenser only if venting really is not an option.
Martin, iadom, kaibart & kwatt…. You’ve been so very helpful. Thank you very much indeed.
