Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hello Everybody ..Ci555. small prob
- This topic has 15 replies, 2 voices, and was last updated 8 years, 6 months ago by
ceedy.
October 8, 2017 at 6:57 pm #92328
ceedy
ParticipantHi all , not been here for a long while , only when the washer is causing probs and when Wife is passing on the earache ๐
To be honest the 555 has been a pretty trouble free device over the years and maybe we ought to retire it . but giving it another chance ๐ .
Had the door not opening after any wash , and found nothing mechanically wrong , but a slighty dodgy solder joint on the control board . reflowed it and all seems ok, but now She has reported that the Prewash does not switch on .?
So unless there is something outside the controller board that can cause this , maybe a new board is is order ? any clues Guys ? .
taChris
PS . my main trouble with the washer is cos its basically so reliable , I only visit it every few years and have to spend a while re familiarising myself with it workings every time , and this get harder the older i get .. ๐ฎ ๐
October 8, 2017 at 7:41 pm #450966iadom
ModeratorRe: Hello Everybody ..Ci555. small prob
Why do you need a prewash anyway, the wash times on these are extremely long on most programmes at the best of times.
It could just be the clear plastic ‘light guide’ that sits between the buttons and the pcb.
October 28, 2017 at 9:16 am #450967ceedy
ParticipantRe: Hello Everybody ..Ci555. small prob
Removed post for the time being.. unless prob surfaces again. :rolls: .
C.October 29, 2017 at 2:48 pm #450968ceedy
Back to the occasional Stuck Door . getting more and more often and now rather too often !
Did this last night, left for a long while and still stuck, unplugged and left all night and it opened this morning ok .But now after another wash it not opening again.
So Board or Door latch ? , seems the ready light doesn’t now come on when the machine is first switched on ( according to the Boss ! ) but will come on when the start/pause buton is pressed ! ..
So leaning towards a faulty control board ?
Any Clues guys ? , got a machine full of School clothes need for tomorrow !! ooer!!
ta.
ChrisOctober 29, 2017 at 3:39 pm #450969iadom
Given the difference in price a new door interlock would be the way forward.
October 29, 2017 at 4:49 pm #450970ceedy
sorted force used but not too much…
the interlock… what an over complicated thing..for what it does,.. :rolls:
C.October 29, 2017 at 6:28 pm #450971iadom
Most appliance engineers would consider the interlock a very simple device. They would also know with years of experience that interlock faults often lead to blown modules.
Thatโs why they would change the door lock ASAP before forcing anything given the very low cost of one.:(
November 7, 2017 at 12:22 pm #450972ceedy
Fitted a New Interlock and not improved it .
The machine finishes its cycle and stops , the interlock does not let the door open unless left for a long time, and the Ready Light does not re-illuminate as it has always done before ..
Does the 555 offer any error codes /diagnosis sequence ?On the verge of buying a new control board. ๐ฎ
ta
Chris
November 7, 2017 at 4:35 pm #450973iadom
Does it actually complete the full spin cycle?
The fault could also be a sticking pressure switch or badly clogged pressure chamber.
Does it open normally if you remove the mains plug or switch off the power as soon as it has finished?
January 6, 2018 at 12:10 pm #450974ceedy
Soory for not coming back but until now the old banger has been performing ok ..
Until this morning .. upon switch on , its just got 2 lighs on and 2 flashing lights.
or
https://i.imgur.com/Jz2Aj2i.mp4
any clues ?
thanks in hope .. ๐
Chris
January 6, 2018 at 1:32 pm #450975iadom
Not one I have seen TBH.
Is the control knob set exactly to a programme and not slightly between settings.
What happens if you press and hold the Start/Pause/Cancel button then wait for the door to unlock then try it again?
January 6, 2018 at 2:10 pm #450976ceedy
its already unlocked ans empty
Holding the Start/Pause/Cancel button does nothing.
All selections are in a correct position, have tried lots of other permutations .The moment the switched on and power button is pressed . the lighta go one in the sequence ..
Spin…… ready …. then the top 2 start flashing. . wierd .. with a set of bearings needed soon too, wondering if its time to retire it ? . pity as the rest is still in top nick
and its a good old washer..
ChrisJanuary 6, 2018 at 2:13 pm #450977iadom
What happens if you unplug from mains for a few minutes.
TBH if the bearings are on the way out then the January sales sound like the best option. ๐
January 6, 2018 at 2:24 pm #450978ceedy
Have pulled out the control board just in case any damp is playing things up , but all dry
Its been unplugged since last night and was like this on first switch on today . and unplageed for the last coupl of hours .
Just considering chucking a 50 quid controller in as its the only complcated part ๐ ? or not ;
C.
January 6, 2018 at 2:30 pm #450979iadom
With dodgy bearings it wouldn’t make sense unless you can afford to throw ยฃ50 away. ๐
