Help needed wiring up electric motor
Home Forums Public Support Forums Help And Support Other Appliances Help needed wiring up electric motor
Viewing 5 posts - 16 through 20 (of 20 total)
  • #479999
    Marky Mark
    Here you go, hopefully it makes sense. Resistance reading between each wire.
    [IMG2=JSON]{“data-align”:”none”,”data-linktype”:”1″,”data-linkurl”:”https://i.ibb.co/JkLkf9z/ELECTRIC-MOTOR-RESISTANCE.jpg”,”data-size”:”full”,”height”:”227″,”width”:”640″,”src”:”https://i.ibb.co/JkLkf9z/ELECTRIC-MOTOR-RESISTANCE.jpg”}[/IMG2]
    #480000
    one thing that stick out quickly is blue and brown are the same connection being zero ohms
    a lot of this is just over pure guess work
    the highest reading is between brown / blue and yellow that suggest this is the neutral cable probably the blue with the brown going to cap
    the other 4 that stick out are yell red white and grey. with similar resistance that add up as a chain these are you speeds starting yell then red white gray
    dont know how many speeds you have
    that leaves black as the other side of the cap
    bear in mind I cant promise anything is a bit of logic and guess work
    have dug around and cant find any tech that gives different motor wiring colours
    Marky Mark
    Thank you again.
    I’ll look into those suggestions this eve. I’ve also asked the motor supplier for a wiring diagram. I’ll update if I get one.
    #480003
    Marky Mark
    I’ve admitted defeat. Well, I sent photos and info to a local spark and he informed me the motor would not be able to connect up to the switches. So I bought a new motor. Which doesn’t work either.
    And now… I think it’s the capacitor that is the broken part (if only I’d checked that first). So I’ve ordered a new capacitor. If that works I’ll send the 2nd new motor back.
