Add. the screws that hold the brushes on to the motor can be very tight and you would probably have a bit of a struggle doing the job from underneath. If so, suggest you remove the motor and do it that way. Remove BOTH brushes and check them ….might be ok after all, in which case I was wrong! If worn out then buy new brushes.
