Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hoover 1500 HSP 15 not starting….
- This topic has 23 replies, 4 voices, and was last updated 8 years, 9 months ago by
Crystallake.
July 6, 2017 at 7:29 pm #448699
Crystallake
ParticipantRe: Hoover 1500 HSP 15 not starting….
electrofix wrote:can only see one cable on the programme selector
please confirm there are 2 mains cable and a small 3 or 4 wire programming cable
dave
Not too sure what you mean. I will get a picture of it uploaded.
Thanks electrofix.
July 6, 2017 at 7:52 pm #448700Crystallake
dave
Thanks electrofix…..
…not too sure what you mean so here’s a piccy of the programme selector….
July 6, 2017 at 8:13 pm #448701Crystallake
kaibart wrote:Looking at the pictures all the wiring looks ok I personally would try a door lock is the handle on the door ok ? Try pressing the start button and carefully try to engage the door lock by using a screwdriver
Thanks kaibart.
I have removed the doorlock (still wired) from the machine and played about with it but still no locking and starting of programme.
I have added this photo for reference as I forgot to add it with all the others…..
July 6, 2017 at 8:13 pm #448702electrofix
ModeratorRe: Hoover 1500 HSP 15 not starting….
switch has 2 sets of wires
mains cables at yellow
and data cable at blueyours is missing
July 6, 2017 at 9:50 pm #448703Crystallake
electrofix wrote:switch has 2 sets of wires
Thanks electrofix,
Weird because, the image of my doorlock switch looks nothing like the image (with arrows) you have uploaded.
Not only this but the image of my doorlock switch in the above set of images was taken before I dismantled the machine and the lock was working fine then.
Confused!!! ❓ :eeek: ❓ :eeek: 😕
July 6, 2017 at 10:04 pm #448704electrofix
ok will use your picture its an earlier version of the switch
follow green arrow there is another plug
looks like there is an unused plug at the bottom of the picture
July 7, 2017 at 9:34 am #448705Crystallake
electrofix wrote:ok will use your picture its an earlier version of the switch
Thanks electrofix.
If you take a look at the original image of that area, the photo showing the programme selector has only one block of cables inserted. This photo was taken before the dismantle and all was well. The unused block (black cable) you mention, is an unused cable, I presume for another model that uses the same cabling loom.
July 7, 2017 at 9:35 am #448706Crystallake
Would just like to say thanks to all who have contributed to my quest to get my W/M sorted.
Hopefully we will get a solution. 😉
July 7, 2017 at 10:19 am #448707Crystallake
WOW!!!!!!!!!
IT’S WORKING!!!!!!!
I CAN”T THANK YOU ALL, ENOUGH!!
I took another look at the programme selector and tucked up behind it was a little connecting area. So I put the unused red cable into it and selected a programme and BOOM! – it started. Weird that the cable was not in it when I started to dismantle.
Maybe it unclipped during the starting of the dismantle????
Just so happy.I REALLY CAN’T THANK YOU ALL – SOOOO PLEASED
(and relieved).Just got a cart load of washing to do now. So worth it though.
THANK YOU ALL EVER SO MUCH!!
