Hoover HNWF washer dryer f12
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover HNWF washer dryer f12
Viewing 15 posts - 1 through 15 (of 17 total)
  • #82109
    allan73
    Hi all, my customer has fitted a new slave timer to the above himself and now gets an f12 fault but only when he uses the dryer.
    Are the codes for these the same as the washers ? I can’t fathom why the communication error only appears on drying programme.
    Thanks Allan
    #418716
    Re: Hoover HNWF washer dryer f12
    Give us the full model number or better still the 8 digit product code (3???????) as that will help decide. 😉
    #418717
    allan73
    Production code is : 31000638
    #418718
    ERROR 12
    Missing Air Heating while Drying: defective NTC Probe for Drying and/or defective Air Heating Element and/or Wiring.
    Bryan
    #418719
    allan73
    Thanks Bryan
    It heats so I’m guessing it’s the NTC.
    Allan
    #418720
    It may be coincidental that the selector switch caused the dryer error though I wonder why the customer replaced it in the first place, please explain?
    There is a specific ‘auto test’ for the dryer only which may help explain what us going on? The dryer module on these is on the base, the dryer selector switch on the panel alongside the main prog selector switch which makes diagnostics challenging. Email me if you need the test manual for this heap of wonderment. 😉
    #418721
    allan73
    Will do thanks Martin. The customer states he changed the selector because ” it was doing strange things and going on the wrong setting”
    Allan
    #418722
    That’s OK then as faulty selectors do that anyway.
    #418723
    allan73
    Had customer take photos of dryer area on this and I can only see stats, no NTC ???
    #418724
    It doesn’t nor never had an NTC. Error 12 is a connection error between the 2 boards. And bugger all to do with NTC’s 😉
    #418725
    allan73
    He’s had the facia off to change the selector. I’ll check ribbon cable and board connections..
    Allan
    #418726
    Theres a 3rd board to be found if you take the back off. 😉
    #418727
    allan73
    Ok I’ll take a look, thanks
    Allan
    #418728
    Never said it did.. just that its the dryer heater fault according to the fault code.
    Bryan
    #418729
    r600a wrote:Never said it did.. just that its the dryer heater fault according to the fault code.
    That’s news to me then Bryan. All I know it what’s listed for that model (and most Hoover/Candys stick to the same error code format)…..
