Hoover Performa 1100 – fill problems – easy repair?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover Performa 1100 – fill problems – easy repair?
Viewing 15 posts - 1 through 15 (of 20 total)
  • #6969
    dekka
    Our Hoover Performa 1100 isn’t filling up with enough water, the clothes are just damp during wash and rinse cycles. It does admit water and it enters the machine fast, but it shuts off too quickly. To get a decent wash I have to add more using a hose from the kitchen tap, same applies to rinsing. Is this problem fairly simple to fix ?
    #120657
    “Performa 1100” is a generic description across various models of Hoover washing machines and will not help us help you. Please check the control panel of the appliance for something like “AC110” or similar.
    Bear in mind that modern washers wash at far lower water levels than previously, so the fact that you can’t see water in the machine may not actually be a fault!
    Please advise model and we can go from there.
    Re: Hoover Performa 1100 – fill problems – easy repair?
    Penguin 45, thank you for replying! The model number of the machine is AC110, apologies for not including that in my post. Because the clothes are just damp during wash and rinses, they don’t smell fresh afterwards and also feel soapy. That’s why I add more water myself, just enough to bring the level to the lower part of the glass. I’ts a nuisance to have to do that all the time. I wondered if there was a water level sensor in the machine which may be faulty.
    Many thanks again, I appreciate your time.
    Dekka
    #120659
    Dave_Conway
    Presumably the spin cycle is OK, are the clothes coming out still wet ?
    It sounds more like a slow draining problem rather than not enough water which is a quite uncommon complaint.
    #120660
    dekka
    Thanks for your reply Dave. It is emptying and spinning ok. Will just live with it, if there had been an easy way to adjust the water level then it would have been great.
    Best wishes for Christmas and 2005 to all.
    #120661
    Hoover Performa 1100 washing machine instruction manual
    Can anyone help with how to get an instruction manual for this machine?
    #120662
    Re: Hoover Performa 1100 washing machine instruction manual
    kioralaura wrote:Can anyone help with how to get an instruction manual for this machine?
    Telephone Hoover (GIAS) Service on 08705 400 600 and ask for a copy (Do give them the FULL model number though 😉
    AC110
    [Am looking for an instruction manual for Hoover Performa 1100 washing machine, also known as AC110. Can anyone help please?
    #120664
    Thanks Martin, sorry, not used to these chat forums and dont know how to find my way round yet. Hence I asked the question twice. Will try phoning Hoover, though I have gone to http://www.saynoto0870.com for a landline number to reduce my costs. Are you aware of this site? Its promoted by http://www.Moneysavingexpert.com too. Keep up the good work.
    #120665
    my boyfriend has moved into a rented house.
    the washing machine that is there is a quattro 1100 AB.
    Neither of us have a clue how to work it!
    I have been on the hoover website and even called gias, but have never got through. can you help me?
    i would be extremely gratefull if you could just tell me how to use the machine on a standard 40c wash!
    Thanyou Vicki
    #120666
    Vicki,
    Do please submit the full model number and we will see if we can help 🙂
    Hi Martin,
    I have a similar problem to Vikki.
    We have just moved into a rented flat where we have a Hoover Quattro System 1100 AB. We have no idea what the different numbers on the Spin Settings apply to.
    If you could shed any light on this I would be grateful.
    Thanks in advance for your help.
    Andy
    #120668
    There is a conceptual problem with posting Hoover model numbers…….. There are hundreds of models, the number will take whoever looks it up for you straight to it. Printed on the control panel and on a label on the door opening surround.
    Thanks for the reply Penguin.
    The numbers around the drum are:
    Mod: AS 110-001
    N: 3761410499491355
    G 0010
    There are 14 settings. Would that information be enough to determine what any of the settings are for?
    Thanks for your feedback.
    #120670
    Dave_Conway
    It would probaly be advisable to order the manual to be honest 😉
    Martin wrote:Telephone Hoover (GIAS) Service on 08705 400 600 and ask for a copy (Do give them the FULL model number though
