Re: Hoover softwave auto-washer 1000
timdowning wrote:If the machine hadn’t spun and there wasn’t much water left in the machine then the fault is due to a blocked pressure chamber. This is a white vessel at the front of the machine. A blockage here will hold the door locked as well.
You will probably find the door opens this morning. 😉
This vessel controls the water level so don’t be tempted to try the machine until you’ve cleaned it out.
You must unplug the machine before attempting the repair. And you must be careful to allign and seal the vessel before running a cycle.
i am with tim on this one
