Hoover VH W6540-80 Washer/Dryer TD overheat stats tripped.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hoover VH W6540-80 Washer/Dryer TD overheat stats tripped.
Viewing 3 posts - 16 through 18 (of 18 total)
  • #410264
    Twoten
    Re: Hoover VH W6540-80 Washer/Dryer TD overheat stats tripp
    Martin wrote:
    So is it a 180 degree TOC that’s fitted on that machine?
    I haven’t managed to get back to it to check, I will update you when I find out. My guess is it will be.
    #410265
    smartin
    check to make sure fan motor isn’t loose in its housing, they are prone to coming loose , causing fan to stop and take out stats.
    #410266
    Twoten
    The fan motor checked out OK.
