Hoover vision HD flashing 3 and 16 times
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hoover vision HD flashing 3 and 16 times
Viewing 9 posts - 16 through 24 (of 24 total)
  • #413327
    Re: Hoover vision HD flashing 3 and 16 times
    I say your problem is the pump. My colleague Bryan is convinced it is the heater. I sit and wait meanwhile the further developments with interest
    Hi Martin
    Thats what we thought at first but after 6 months of doing GIAS work direct and tech I think tech will win.
    Also your appliance has a maximum repair cost of £119 including all parts & labour if done through hoover/candy
    Bryan
    #413328
    I watch with interest 😀
    #413329
    lateintheday
    Hi chaps, I haven’t ruled out that both of you are right!
    With the dirty washing backing up I tried to find a workaround for now since the parts shop want me to return the element before they order the new part – looking at another few days without the washer apparently.
    I found that after the wash cycle stops, if I put the machine onto drain it makes all the right noises for a couple of minutes but then won’t let me rinse. However, if I pause the washer after the wash cycle and open the filter, quite a lot of water comes out. Then it does let me do the rinse and spin. Almost as though the weight of the water is too great for the motor.
    Tempted to get a new pump because of this – plus, it can’t hurt matters.
    #413330
    lateintheday
    New pump (ASKOLL) arrived today. Typically, the electrical connections are different – the old pump had parallel terminals and connected by a plastic encased block.The new pump has a perpendicular arrangement. I note that this can be replaced with separate spade connections, but do they need to be anything special? Insulated or just bog standard.
    #413331
    Insulating tape with suffice.
    #413332
    lateintheday
    thanks Martin
    #413333
    Let us know how you get on…… 😀
    #413334
    lateintheday
    SUCCESS! 😀
    Just finished the first load. Turned out to be the drain pump after all – well done and huge thanks Martin. Thanks also Bryan for your input.
    For those with similar issues, can I just add that I’m sure a tech would have spotted this within minutes. I had watched the old pump’s impeller spin and to be honest, it looked fine (even when taken out) and it sounded quiet. However, as soon as the new pump kicked in, there was a really clear gurgling noise as water gushed through the system/standpipe.
    I guess I’m not as observant as I thought – the noise difference was so obvious.
    #413335
    lateintheday wrote:SUCCESS! 😀
    Well I never, fancy that eh! 😀 😉
