Hotpoint 8596p Mistral plus, stuck in defrost?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint 8596p Mistral plus, stuck in defrost?
Viewing 2 posts - 16 through 17 (of 17 total)
  • #141416
    Re: Hotpoint 8596p Mistral plus, stuck in defrost?
    Hi I have the same problem and once I gave up an replaced the fridge with a new one the old one started to work fine, this continued untill I moved it last week and now it is back to its old tricks.
    I have been told it is down to the defrost stat, but I have not worked out which one this is yet.
    I hope this helps a little and if you work it out please let me know….
    #141417
    pete69
    Hi Mark
    Well, I ended up having to replace the thing. As it was impossible to go any longer without a reliable unit. However I still have it and will be having another look at it, when time permits.
    these units don’t actually have a thermostat as far as I can see, they seem to sense temperature by using a thermistor, heat shrunk onto a length of wire (a process that seems to magically transform a 70p thermistor into a £15-25 product depending where you buy it) i still hope to repair it as a family member can use it.
    Peter.
