Hotpoint brushes – laminated vs thin.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint brushes – laminated vs thin.
Viewing 15 posts - 1 through 15 (of 29 total)
  • #13411
    This is prompted by Goatboy’s recent post in Labour rates.
    I use the thin ones now because I found so many laminateds split and sticking in their holders in less time than it takes to wear down the thin ones.
    Mind you, I’m asking myself if I shouldn’t have checked the pump/sump more thoroughly each time I found brushes split.
    Mike.
    #154732
    cornwell40
    Re: Hotpoint brushes – laminated vs thin.
    I went back to the 161460 thin brush about six months ago. The laminated ones were burning out for fun, regardless of pumps.
    There is another post on this very subject from a few months ago!!!
    Tony C
    #154733
    Goatboy
    Errr….I can’t find that other post. Maybe a mod will, and move these posts there 😉
    We used to ask the customer how much washing they did, and fit the black ones if it was only a couple of washes a week. But we end up fitting so few black ones, we just phased them out eventually.
    I’ve had 1 or 2 splitting white ones, but not that many. Not enough for me to try some other brushes.
    What I do see, is alot of burnt out armatures because of non-gen brushes, fitted by DIY tards!! 😕
    #154734
    Tony C
    Yeah, I did a search after posting and found 19 matches for “laminated”.
    There is much to learn!
    😀 Mike.
    #154735
    Anyway, who’s complaining about getting another brush job two years down the line? 😈
    Mike.
    #154736
    legsthediver
    Hotpoint had a problem about a year back with Lam brushes.. They changed supplier (you can tell the difference by th holder which is “off” white.. These burn up to buggary ! They are back with origional supplier now and all seems well.
    #154737
    Goatboy wrote:Errr….I can’t find that other post. Maybe a mod will, and move these posts there 😉
    Here is the other thread on the same subject :-
    http://www.ukwhitegoods.co.uk/modules.p … 23&start=0
    #154738
    roly16
    I never changed over from the black brushes because of the number of split laminated ones I found.
    #154739
    I have always just used the white ones on 1200 spin machines and black ones on the slower spin models.
    #154740
    bobokines
    There was a Hotpoint Technical Bulletin about this about 8 years or so ago. Any machine with digital controls should have Lam brushes as the brushes soak up some of the radio interference.
    I only ever use laminated brushes and have only ever notice a problem with short brush life when there is a blocked or faulty drain pump. If the brushes are burned, I explain to the customer my reason for changing the drain pump and won’t give a gtee on the repair unless a new pump is fitted.
    Bob
    #154741
    megawatt
    I had a bad batch of laminated about 9 months ago. When they failed(as most of them did),they left a brown mark down the side.
    I still use laminated due to the short life of the thin ones.
    Spin inhibit on newer M/C’s should have stopped pumps causing carbon problems.
    Mike.
    #154742
    Fit 10 to 15 sets a week, had severe problmes for over 12 months, last six months the white holder( original) ones have been fine.
    #154743
    161460 now obsolete – get ’em while you can.
    Another cunning ploy by Hotpoint perhaps? Ensure that the remaining GEC motors get cooked by the awful 1600474…….
    Or am I being paranoid?
    Obsolete ?8O
    Better get that bulk buying scheme under way right now.
    Mike.
    #154745
    Dave_Conway
    How much are you paying for these by the way (161460) ?
    If you want a bulk deal I’ll do it, name the price and I’ll see what I can come up with 😀
    There are still some left 😉
