Hotpoint – Change the bearings.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint – Change the bearings.
Viewing 9 posts - 16 through 24 (of 24 total)
  • #122571
    Re: Hotpoint – Change the bearings.
    peeler40 wrote: It was drilled after the bearing not before the bearing so any water that got passed the seal went through the bearing instead of escaping down the drain hole
    Whilst that is very true, the holes positioning was wrong. However, it did not deal with the fundamental problem as to premature failure. In fact the ‘modified’ complete drum assemblies have not really solved anything and will still have a very short life.
    I believe the problem lies in the fact that Hotpoint have made no provision for ‘static discharge’, and no longer put an earth grounding on the bearing hub as they used to way back on the 95 series. Electrostatic forces come into play very much on these modern high speed, high torque units and generate enough destructive powers on the knife edge water seal by themselves. (After all, it’s the water seal that fails here and not the bearing, no matter where the hole is or was) Add to that, the corrosive effect of detergent, water hardness, stray fibres and pet hairs and we are very much talking of the ideal senario for early breakdown every time.
    ‘Modified’ ????? I think not ๐Ÿ™
    can anyone give me the repair manual for a wma 31
    #122573
    No, even the trade can’t get them. What do you wish to know?
    cheny
    swindon wrote:can anyone give me the repair manual for a wma 31
    Hi ๐Ÿ˜†
    I have started to get a loud banging noise ๐Ÿ˜• could this be the said bearing? also cannot work out how to get the drum out unless as someone already said use a can opener.
    Any help will be very much appreciated.
    Normally I would have no problem with repairs but cannot work out how to get apart to the drum
    cheers
    Cheny
    #122575
    Cheny,
    If this machine is under 5 years old, contact Hotpoint. They will come and replace the drum unit for you for ยฃ90. To be honest, you will nit be able to buy the neccessary parts for that sort of money.
    But they have, the belt is electrically conductive, one very good reason to use genuine belts only on these models.
    PS. sorry about the post in the ‘finnish’ saga thread. I won’t do it again. ๐Ÿ˜ณ
    #122577
    iadom wrote:But they have, the belt is electrically conductive, one very good reason to use genuine belts only on these models.
    Well flip my old boots I never knew that ๐Ÿ˜ฏ
    I got one out from my vast stock mind you, just to check with my ‘Metrohm’ and by golly gosh, the man’s right ๐Ÿ˜€
    …there’s always something new to learn every day from this site…guaranteed :tup:
    P.S So! my theory of Hotpoint bearing failures has taken a dive as a result of this revelation. However, I know conclude the failure rate is due simply to inferior quality materials being used ๐Ÿ˜€
    #122578
    mozthemagiceagle
    Any chance anyone can tell me which parts are required as the links below no longer go to the products.
    Many Thanks
    Moz
    Postby Dave_Conway ยป Tue Jan 04, 2005 4:43 pm
    Ozzy wrote:Who is the “we” that will provide the bearing kit?
    UK Whitegoods collectively.
    The bearing kit is only ยฃ15 on this site ๐Ÿ˜‰ but you’ll also need the seal that goes in between the two halves of the tub plus postage hence the “around ยฃ40” estimate which was a little high admittedly ๐Ÿ˜ณ
    The kit is available here
    The seal is here
    #122579
    Links updated, thanks. It’s a nightmare keeping track of all the links on here so it’s nice to be told when they’re broken. ๐Ÿ™‚
    Do watch the bearing size though as they used the 30mm kit in some and the 35mm on others. The tub gasket is the same for all though.
    HTH
