Hotpoint Condenser Tumble Dryer tripping
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Condenser Tumble Dryer tripping
Viewing 5 posts - 16 through 20 (of 20 total)
  • #287397
    Bernie
    Re: Hotpoint Condenser Tumble Dryer tripping
    Had a look for part No. C00264260 on Connections website but – “Sorry, no results match your search for “C00264260”
    I even tried Hotpoint’s website but could not find it there either.
    Bernie
    #287398
    evo1
    depending on where the machine is (ie flooring), just drill a 3mm hole at the lowest point, and glue some dense foam on the outside over the top off the hole, like a foam nappy, also check that the hole in the wall if they had a vented machine is sealed off, filled in or blocked, as cold air coming through that and hitting the rear cover will cause your problem as any moist air inside the cover will condensate, turn to water and trip the heater
    #287399
    Bernie
    Thanks evo1
    #287400
    bmrenr
    Hi Bernie how did you get on with this?I have the same prob with an Indesit dryer.
    Tom.
    #287401
    Bernie
    Hi Tom
    Sorry can’t remember what I did, either I fitted a pump or I did as evo1 suggested. I know what ever I did, I did not get any call backs.
    Bernie
