Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint Drum/Spider Advice
- This topic has 18 replies, 8 voices, and was last updated 16 years ago by
Allsorts.
March 15, 2010 at 8:50 pm #53257
Allsorts
ParticipantWhat do you all do if you have a lovely balanced drum but the bearings have gone and took the spider with them. These are beginnning to become a pain in the asterix.. I have a load of drums here that need new spiders but they are bar stewards to get off and I have broken so many torx bits trying.
cheers
GeorgeMarch 15, 2010 at 9:53 pm #315123megawatt
ParticipantRe: Hotpoint Drum/Spider Advise
Drill them off is the best way.
March 15, 2010 at 10:22 pm #315124iadom
ModeratorRe: Hotpoint Drum/Spider Advise
Some people use an angle grinder but I use a titanium drill bit to drill out the bolt heads, lasts ages and drills them off in no time at all.
Used to use the bullitt drill bits but they didn’t last for a single drum most of the time.
The genuine bolts are a bit pricey but I think there is a non gen alternative that is quite cheap.Still working my way through a bagful donated to me by a retiring ex colleague.
March 15, 2010 at 11:37 pm #315125Allsorts
Ok guys… will try with Titanium as soon as I can.. Thx for the tips… hate losing good drums.
March 16, 2010 at 9:01 am #315126Phidom
I’m probably wasting my breath but usually you don’t need to change the spider on the large drum Hotpoints as the seal does not run on the shaft surface.
March 16, 2010 at 10:47 am #315127iadom
I would agree, I would guess that I change the spider on one in five bearing/rear half jobs, just clean up the shaft most of the time.
March 16, 2010 at 10:54 am #315128Madmac
Me too but have noticed the 30mm ones are very unforgiving of even a trace of play once back together 😯 Had one fail in under a month a while back :rolls:
Bearing lock fluid might help on some of them ❓March 16, 2010 at 11:06 am #315129iadom
I did mean the 35mm ones, wouldn’t risk it on a 30mm shaft/bearing, just not up to the job in the first place.
It would be new 35mm spider and bearings/rear half or nothing.
March 16, 2010 at 11:19 pm #315130Allsorts
Yes, I agree, I don’t normally change the spiders but on these ones here the bearings have worn into the shafts.
George
March 16, 2010 at 11:49 pm #315131iadom
Well, I had a 35mm spider/drum rear half change this afternoon. The drum shaft was totally unmarked, shiny as new, only problem was that the drum support was in four pieces. 😀
March 17, 2010 at 7:16 pm #315132Allsorts
Yup, Had that one too.. but in that case the drum was damaged, as was the outer drum front & rear… Only thing that was in tact was the bearings 😆
March 17, 2010 at 9:07 pm #315133johnnyj
If the torx screws are not to rusty i find if you give the heads a good couple of wacks with a drift, most of the time they will unscrew fairly easily if you need to drill out as Jim says a Titanium drill does the job,JJ
March 18, 2010 at 8:00 am #315134Dales-Electronic
Just for info the bolts used on Zanussi automatics fit the Hotpoint spider and being 10mm headed dont cause further problems.
March 20, 2010 at 11:19 am #315135electrofix
have got bots out sometimes after heating with blowlamp but most of the time drill is only answer
using a 30 torx head on these bolts is silly 40 would be nearer the mark but no doubt indes**t had there reasons
March 20, 2010 at 12:52 pm #315136Phidom
If there’s slight wear on the shaft where the bearings go you can try Loctite Bearing Fit. You do need to degrease the surface carefully.
