Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint Futura FDFL11010
- This topic has 18 replies, 3 voices, and was last updated 5 years, 1 month ago by
scrappydoo.
February 22, 2021 at 7:13 pm #99186
scrappydoo
ParticipantGot a Hotpoint Futura FDFL11010 that’s got an annoying bottom leakage. Thought initially it was the sump seal so changed that (well changed the whole sump as comes complete) still no better. I then changed the drain pump as I thought the O ring could be leaking but still no better. I’ve now suspended it on wood to watch it go through a cycle and can see the leak was coming from the black mastic like area where it’s been left with + like cut in the material. I sealed these up and the leak just moved a little. What could cause water to leak onto the mastic cover?
This is (to my knowledge) just a protective cover over the steel frame to prevent scratching/damage of the steel from below. How would water get between this mastic like cover and the steel, I’m not sure how it’s even possible….bloomin’ frustrating!
Thanks in advance!
February 22, 2021 at 9:32 pm #475332kaibart
ModeratorThe dishwasher may well be overfilling by the sounds of it,have you checked that the spray arms are not split or blocked aswell
February 22, 2021 at 11:20 pm #475333scrappydoo
Participantkaibart wrote:The dishwasher may well be overfilling by the sounds of it,have you checked that the spray arms are not split or blocked aswell
Doesn’t appear to be but your theory makes sense. Would anything else cause overfilling? Water valve appears to shut off.
February 23, 2021 at 7:01 am #475334kaibart
ModeratorThere is a litres counter i think its the left hand side the valve doesn’t know how much water to fill with so this is done by either the litres counter or the pressure switch on dishwashers if for example it fills with 2 litres of water and thats the correct fill level the water stops at that point if the litres counter is faulty it could fill with 3 litres then switch off the water hence over filling hope this helps you
February 23, 2021 at 11:07 pm #475335scrappydoo
ParticipantAny way of testing this valve?
February 23, 2021 at 11:35 pm #475336electrofix
Moderatorthe valve is not what Kai is suggesting is faulty rather than the way of measuring the amount of water entering the appliance
February 23, 2021 at 11:43 pm #475337scrappydoo
Participantelectrofix wrote:the valve is not what Kai is suggesting is faulty rather than the way of measuring the amount of water entering the appliance
Sorry, I misunderstood. Is there a way of testing this in anyway?
February 24, 2021 at 12:01 am #475338electrofix
Moderatoram a little worried about your description of where the leak is coming from
and chance of a pic to show us where
you may have to host it on another site and post a public link
February 24, 2021 at 12:30 am #475339electrofix
Moderatorwhere this is leaking from is odd the black mastic is only for sound deadening but your saying it was leaking through a crack in this
there is only 2 reasons for that
1 the water is getting behind it and running underneath from higher up
or
2 there is a crack in your stainless steel tubDave
February 24, 2021 at 12:50 am #475340scrappydoo
ParticipantI’m glad I’m not going mad, it’s a strange one isn’t it. I can’t see any obvious cracks/issues with the tub. There’s nowhere obvious where it looks like it could be leaking from The overfilling makes the most sense.
February 24, 2021 at 6:48 am #475341kaibart
ModeratorThe pictures you have posted and the area where you are saying its leaking i have to agree with dave I think there’s a crack in the stainless steel tub as if it was overfilling it would more likely leak from the flange where the door opens and closes
February 24, 2021 at 9:47 am #475342scrappydoo
Participantkaibart wrote:The pictures you have posted and the area where you are saying its leaking i have to agree with dave I think there’s a crack in the stainless steel tub as if it was overfilling it would more likely leak from the flange where the door opens and closes
Where is it most likely to crack would you think? I’ll have a thorough look again.
February 24, 2021 at 10:10 am #475343electrofix
Moderatorwell there is no reason why you cant take off the sound deadening material and take it off a bit at a time till you find the leak. then it can be plugged from underneath
February 24, 2021 at 10:27 am #475344scrappydoo
Participantelectrofix wrote:well there is no reason why you cant take off the sound deadening material and take it off a bit at a time till you find the leak. then it can be plugged from underneath
Might well have a go at that later!
March 2, 2021 at 2:10 am #475345scrappydoo
ParticipantHave removed all the mastic/sound deadening material. Ran the dishwasher and the leak is now coming from the sump. I’ve just replaced it (had to to buy a new seal). Is there a specific torque for the sump bolts I may have missed, or a procedure I have overlooked when replacing it?
