Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint Rpd10657 washing machine
- This topic has 15 replies, 2 voices, and was last updated 5 years, 3 months ago by
No10chris.
December 16, 2020 at 12:00 am #98799
No10chris
ParticipantI’ve just had the main board repaired, putting it back in and I’ve got a plug with 2 red wires that I can’t see where it goes, unless I’m going blind , anyone have any ideas
December 16, 2020 at 12:18 am #473840electrofix
Moderatoronly plug i can see with 2 red wires is for the direct injection pump
shows it placed between 2 other plugs. opposite test plug, there is one plug at the top, the one you have got should go between the next 2
December 16, 2020 at 6:05 am #473841No10chris
ParticipantCheers Dave, I laid it on its side and found it,, next problem is it’s still dead, I’m wondering if it’s popped the power supply box ,, think I have a spare luckily
December 16, 2020 at 9:53 am #473842electrofix
Moderatorpower supply box ??
all mains power supplies are in the board you have changed
since this unit wont function without display board chech the display is plugged in securely to the centre connector, bottom og the main board
what was the fault with the board that needed fixing originally ?
December 16, 2020 at 3:23 pm #473843No10chris
ParticipantI’m thinking the bit where the cable comes in, I’ll check all connections, it had f12 then went dead, I sent board off to a place I’ve used any time I’ve needed,, so I’m sure that’s ok,,
December 16, 2020 at 8:35 pm #473844electrofix
Moderatorwhen i used to get faults like this, i would sent the board as a pair so they could be tested together
this could be a display board fault
December 16, 2020 at 9:50 pm #473845No10chris
ParticipantI wouldn’t have a clue as to where to send to have it repaired if it is that, I’ll recheck all connections and get back to you,, thanks for your help
December 16, 2020 at 10:04 pm #473846electrofix
Moderatortry asking
the other one who did repairs was QER
website still there so i assume they are still trading
December 17, 2020 at 5:54 pm #473847No10chris
ParticipantThat’s who repaired the module,, I’ll give them a shout after I’ve double checked everything,, bad arthritis day today, so not gonna happen
December 19, 2020 at 2:19 pm #473848No10chris
ParticipantTrying to take the top pub out, it seems to be attached to the programme knob, is it just pull or something else holding it ?
December 19, 2020 at 6:36 pm #473849electrofix
Moderatorunfortunatly the manual dont give that info
December 19, 2020 at 11:20 pm #473850No10chris
ParticipantHi Dave, found a replacement on eBay for £30, does that sound about right,, all the numbers the same, except serial number ( obviously that would be different ),, I’m getting ear hole treatment now as it’s in the kitchen,,
December 20, 2020 at 12:36 am #473851electrofix
Moderatornot sure which board you found on ebay but to work both machines would have to have the same model, commercial code and be in a similar serial range
When you buy a new hotpoint board they come unprogrammed and the software has to put onto it..
if you buy a board with different software it wont workd But emw may be able to re programme it
December 20, 2020 at 12:49 am #473852No10chris
ParticipantOnly difference is it’s off a 8 kg, mines a 10 kg wash. Otherwise the same machine, I’m thinking as it only tells the module what to do, it should work ?
if it wasn’t for the fact it’s only 2 yrs old I would of scrapped it,,
do you have any idea roughly what they charge to re programme the boardDecember 20, 2020 at 9:18 am #473853electrofix
Moderatori suggest you ring EMW
tell them you are having problems and ask if you can send both boards back for them to test as a pair
or
claim on the part warranty but you would have to pay Hotpoints call out and labour but parts would be free no matter how many are neededyou still cannot say the board would work, have had beko boards off identical machines that wont work because they talk to the front panel differently
expect something like £20 plus p&p to programme board but you need to ask if they can do it. you also need to ask if they have a full function test for your board because if they have not, they cant test it properly, so they cant be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain it will work
