Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint TCM580 Belt not lasting
- This topic has 18 replies, 8 voices, and was last updated 12 years, 6 months ago by
Twoten.
September 16, 2013 at 6:55 am #401128
Muv
ParticipantRe: Hotpoint TCM580 Belt not lasting
Ive noticed on quite a few of the Hotpoint CTD & VTD types, that as it stops to gomin to reverse tumble, that the drum hasnt completely stopped turning before the motor has been switched to turn in the other direction, hence allowing motor pulley to freely spin on the belt…and this is when drum is unloaded!
MartinSeptember 16, 2013 at 7:27 am #401129Twoten
Thanks for the information.
kwatt wrote:If there’s something up with the jockey wheel or pulley it’d throw the belt before it burnt through it or the faulty would have been that it was as noisy as hell.
K.I don’t know how many of these jockey wheels I’ve changed for one reason or another but the customer doesn’t mention it being noisy but I agree with your point if the load is too heavy for whatever reason it is likely to slip at the pulley. When these wear I find the belt shreds before it breaks.
iodom wrote:The jockey pulley on these does seize up occasionally , belt stays on but binds on pulley.
Do to the use this machine gets and the lifespan of these pulleys I think I will replace it anyway.
Muv wrote:
Ive noticed on quite a few of the Hotpoint CTD & VTD types, that as it stops to gomin to reverse tumble, that the drum hasnt completely stopped turning before the motor has been switched to turn in the other direction, hence allowing motor pulley to freely spin on the belt…and this is when drum is unloaded!I will check for this, I have noticed this before on other machines.
Thanks for the advice everyone.
September 16, 2013 at 8:02 am #401130iadom
ModeratorRe: Hotpoint TCM580 Belt not lasting
In reply to that last point, if the drum spins freely during reverse then the belt is unbelievably slack and would wear through in no time. Never, ever seen a belt so loose that the motor will spin freely. ❓
September 16, 2013 at 9:12 am #401131Muv
It is mostly related to poor tension on a worn belt, but i have fitted a few genuine belts, and still seems to happen…seems to be more of a timing issue with the reversing
Martin -
