Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WD440 Blocked Dryer Assy ?
- This topic has 18 replies, 8 voices, and was last updated 17 years ago by
Turbo.
March 26, 2009 at 8:01 pm #44554
Turbo
ParticipantThis dryer is only 18 months old and has had very little use. On test with the door open the dryer motor runs but there is a very poor flow of hot air coming from the heater box. Have checked inside heater box which looks like new. If it is a blockage what is the best way to clean it out.
Also are there any mods to this particular model, the serial number is 707060191.
Thanks GrahamMarch 26, 2009 at 8:15 pm #281411BobHope
ParticipantRe: Hotpoint WD440 Blocked Dryer Assy ?
Hi Graham,
have you checked / cleaned the flushing filter at the rear of the heater box. ?
BobMarch 26, 2009 at 8:23 pm #281412Turbo
Hi Bob
No not done one before, how do you access the dryer filter?
Looking from the top with the heater duct off it just looked like the condenser unit was part of the drum and impossible to clean out.
GrahamMarch 26, 2009 at 8:33 pm #281413BobHope
did you remove the top of the heater box or the complete assembly.
bob
March 26, 2009 at 8:42 pm #281414Turbo
Just the aluminuim heater box.
March 26, 2009 at 8:45 pm #281415BobHope
at the rear lefthand side of the heater box did you remove a pipe that goes to the water soliniods.
this pipe has to be removed to allow the box to come off.
bob.
March 26, 2009 at 8:59 pm #281416Turbo
No I did not remove any pipes so it looks like I will have to go back and dig a bit deeper. Thanks Bob
GrahamMarch 27, 2009 at 12:21 am #281417helo_75
Participantcut that stupid filter off, and disable th flushing valve
only then will it work correctly
March 27, 2009 at 12:23 am #281418Penguin45
Participanthelo_75 wrote:cut that stupid filter off, and disable th flushing valve
For a while………
:p45:
March 27, 2009 at 9:00 am #281419Ashby
Hi, Had one of these myself, similar problem.
The motor was running ok but the fan was slipping on the shaft and not turning. Got a new fan kit from Masterpart.
AshbyMarch 29, 2009 at 10:14 am #281420Turbo
Went back and cleaned the filter out working fine now, may bin the filter the next time it happens.
Thanks for all the help.
GrahamMarch 29, 2009 at 12:17 pm #281421eastlmark
ModeratorRe: Hotpoint WD440 Blocked Dryer Assy ?
Turbo wrote:Went back and cleaned the filter out working fine now, may bin the filter the next time it happens.
Grahamthat’l be next month then 😆
March 29, 2009 at 1:51 pm #281422helo_75
ParticipantPenguin45 wrote:
helo_75 wrote:
cut that stupid filter off, and disable th flushing valveonly then will it work correctly
For a while………
:p45:
yup, untill the element fails, or the fan motor, or the thermal fuse, or the pcb, or the bearings, or the doors seal, etc, etc, etc
is there ANYTHING ON THAT MACHINE THATS RELIABLE?
March 29, 2009 at 4:27 pm #281423robbra
Nice quality glass in the door 😆
March 29, 2009 at 5:08 pm #281424helo_75
Participantwhich catches on the drum, and scratches then smashes
