Hotpoint WD62P pressure switch hunts following fill.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WD62P pressure switch hunts following fill.
Viewing 16 post (of 16 total)
  • #269949
    Twoten
    Re: Hotpoint WD62P pressure switch hunts following fill.
    neilsukwg wrote:Did you solve the mystery in the end Twoten?
    Unfortunately not.
    Checked the sump hose, fitted straight without any twists or kinks.
    I removed the pressure hose and tested in a bowl of water, no pinholes.
    I removed the pressure chamber and double checked for damage in case air was escaping.
    Nothing found!
    I notice once the machine has filled the fault can be reproduced by ‘bouncing’ the tub slightly.
