Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WM64
- This topic has 19 replies, 6 voices, and was last updated 18 years, 6 months ago by
dachwilson.
October 8, 2007 at 4:41 pm #228528
ModeratorRe: Hotpoint WM64
Phidom wrote: I think they must have changed the metal alloy on those in recent years as they now fail in very large numbers whereas this was a fairly rare fault on pre WM models..
No change at all that I am aware of. Its due to changes in detergents, particularly the use of liquids that don’t contain bleach, and the overuse of the ‘economy’ features that all modern machines have, It will get worse with this barmy ‘turn to 30°’ campaign. If Proctor & Gamble had the common sense to put a warning on their packaging advising customers of the need to do a maintenance wash that would help but do they, oh no.
Drum supports have been failing in large numbers in this very soft water area for at least 15 years or more.
October 8, 2007 at 7:51 pm #228529richardable
ParticipantRe: Hotpoint WM64
jims right, get a local engineer in to check it out. find one in your area from this site. a proffesional engineer will probably charge you an estimate fee and then its up to you. today i called on a noisy wm64 …bearings collapsed when i got the drum out, the shaft on the spyder was ruined and the outer shell of the inner bearing was immovable. one for the skip!!!BER. 🙁
richardOctober 9, 2007 at 7:29 am #228530dachwilson
Thanks for all your help guys.
We’ve also noticed now that the door has a crack in it – so given all the other things that are slowly & surely going wrong with this machine, we are going to get a new one.
Talked to the Mrs about ISE 10 (even though budget is about £500) – but she dosn’t like the drop down door …can anyone explain why its there – it feels like it will just get in the way when you are trying to empty the machine.
ISE 5 is also an option – but I can’t find anything that details all the wash cycles. Mrs is insistant that she knows what it can do before we buy one..fair enough really.
Was also considering Bosch – can you suggest a good machine from there – able to cope with loads from 3 kids & 2 adults.
Finally noticed LG do an (expensive ) Steam washer…what do u thik of that machine…?
Cheers guys
October 9, 2007 at 10:09 am #228531iadom
Do you have a dishwasher? Everyone who has, manages to load and unload them via a drop down door. The door is very robust and in fact is very handy for pulling the clothes out and lying them on it instead of some items dropping on the floor. It also means that the rubber door seal is not subjected to the severe wear and tear of a normal, glass door machine.
October 10, 2007 at 12:05 pm #228532dachwilson
Taken the plunge & ordered ISE 10……… hope its as good as the write ups say !
