How do you drain off a flooded WMA?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries How do you drain off a flooded WMA?
Viewing 9 posts - 16 through 24 (of 24 total)
  • #173516
    Re: How do you drain off a flooded WMA?
    I’m still waiting for a certain someone 😉 to suggest drilling a large hole in the drum, poking a hose in to syphon then, filling the hole with plastic putty. 😆
    #173517
    whitevanman
    could get one off these shove connecting drain hose on pump down sink.
    pump fits on drill from draper £7.09
    Another Tip:
    Problem :How do you drain a dish washer when the pump has failed
    Tip: remove top spray arm, put bucket/bowl under this, close door and let the circ motor drain it.
    #173518
    funkyboogy
    what if circ motor and pump are combined ?
    #173519
    whitevanman
    A jug/cup would help or this jiggle syphon
    from sealey costs £6.56
    could try placing mouth around drain hose end and sucking like some of of dangerous engineers :rotfl:
    #173520
    whitevanman
    error posted twice please can you delete this
    #173521
    iadom wrote:I’m still waiting for a certain someone 😉 to suggest drilling a large hole in the drum, poking a hose in to syphon then, filling the hole with plastic putty. 😆
    Not a bad idea really. I’d suggest some debor and a rubber grommet to seal afterwards as when the putty hardens it can shake loose from the hole. 😀
    Mike.
    #173522
    whitevanman wrote:Problem :How do you drain a dish washer when the pump has failed? Tip: remove top spray arm, put bucket/bowl under this, close door and let the circ motor drain it.
    We must start a fresh topic entitled… “Engineers Tip of the Week!”
    This one has it for me, thanks WMV :tup:
    All these years I been using a short length of 15mm tubing, filling the tube with water just like my old pal Archimedes taught me way back when? Drains every drop that way and you don’t need electridally 😛
    Jug, Jiggle & Sucking?……no thanks I don’t care for dishwasher soup :rotfl:
    #173523
    walnut
    Shove a Car pump on the end of the drain hose and pump like buggery,
    works every time.
    Argos – Vento Track Pump. 0362827
    #173524
    Dave_Conway
    walnut wrote:pump like buggery
    Now where’s my Carry On phrase book ? 😆
