how hard to blow?
Viewing 6 posts - 16 through 21 (of 21 total)
  • #228404
    freddieboy
    Re: how hard to blow?
    thanks everyone for your help and comments i am still waiting for the new analogical switch ,which sounds as if i will need that now even if it wasnt the original problem(as i blew up it ) this all started because the machine would not fill with water,this has put me off zanussi for life i always thought if you bought a good brand it would last(13 months)i will let you know how i go on when it arrives.once again thanks alot.
    #228405
    freddieboy
    hi everyone ,well the new analogical switch came i put it on and it has not fixed the problem but the machine seems to have gone back to its original fault being that it is not letting any water into the machine.i have checked the system for any blockages the chamber is clean and so are the tubes(i have already changed the celonoid thinking that was the original fault) has anyone has anymore ideas what it could be?
    #228406
    adamhornsby
    Have you had any work done to the plumbing in your house? As this could be reducing pressure.
    #228407
    freddieboy
    no the pressure is fine .i will pull it all apart again and check the system if i cannot sort it out i am going to put the thing on ebay as spares or repair and by anew one but not a zanussi.
    #228408
    helo_75
    ill put money on the pump being o/c
    #228409
    freddieboy
    no, the pump seems to work .it spins when it drains .i think its down to the pcb now as the super rinse light comes on when you turn the machine to a wash which will go out if you press the button.any body with any more ideas ?
