Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Ikea whirlpool DWF 416
- This topic has 16 replies, 2 voices, and was last updated 7 years, 2 months ago by
Gazza.simpkins@gmail.com.
February 9, 2019 at 10:21 am #95456
ParticipantI have a problem with the dishwasher mentioned. The start button light is continuously flashing and continuously beeping. It will not start/finish and sounds like it’s trying to empty even though there is no water in the bottom under the filter. Any help would be greatly appreciated.
February 9, 2019 at 11:18 am #460413electrofix
Moderatorpress and hold the start button and it should reset
if fault re occurs then look carefully at the flashing light. count the number of flashes and see if there is a pattern . if you cant see a pattern its probably fault 1 which flashes once then pauses so it look continuous. if that the case the machine is reporting NTC failure. first thing to check is the wires in the door as it leave the bottom of the door as they are prone to break. be careful as lots of wires are the same colour so you have to know which one goes where
February 9, 2019 at 11:26 am #460414Gazza.simpkins@gmail.com
ParticipantThanks Dave, I will check it out
February 9, 2019 at 12:19 pm #460415Gazza.simpkins@gmail.com
ParticipantHave taken a cursory look at the wires under the door and I can’t see any breaks in the wire. The start light is blinking twice then pause then blink twice etc.
February 9, 2019 at 12:35 pm #460416electrofix
Moderatorfault 2 is water leakage
in the base of the machine where the motor is etc is a polystyrene float that detects water take the lower cove off under the door, mop out water ( plug out) . Then run machine with cover off while watching for leaks
February 10, 2019 at 2:48 pm #460417Gazza.simpkins@gmail.com
ParticipantI have taken off the front cover and yes, it was full of water. Cleaned and restarted, it’s leaking. I can’t see exactly where it’s coming from but it’s spraying the back plate at the far right side. I think it may be the main motor at the back right, and maybe a pipe is loose or something. Without actually taking the whole unit out there’s no way to get to it as far as I can tell. Is this a common fault, ie a circlip just needs a tighten or something? Thanks
February 10, 2019 at 3:37 pm #460418electrofix
Moderatorthere is a hose coming out of the main motor sounds like this is split. water is under pressure at this point so it will spray out
got 2 models with same model number so need the long 12nc to see which you have
early one seems to be a hose later one this hose seems to come with the motor
have had this hose fail a few times
DaveFebruary 10, 2019 at 4:47 pm #460419Gazza.simpkins@gmail.com
ParticipantWhere can I get a replacement hose? Looked online but not found one. Thanks again.
February 10, 2019 at 4:52 pm #460420Gazza.simpkins@gmail.com
ParticipantJust looked on here and found a hose that fits the dwf 415. Would that fit mine?
February 10, 2019 at 4:54 pm #460421electrofix
Moderatorgive me the link
or
do you mean this one
https://shop.ukwhitegoods.co.uk/481253029437-dishwasher-motor-connection-hose
if the hose on your machine look like this one then there is a good chance it will fit
February 10, 2019 at 5:03 pm #460422Gazza.simpkins@gmail.com
ParticipantThanks Dave, will pull it out next weekend. Can wash up by hand until then.
February 10, 2019 at 5:10 pm #460423electrofix
Moderatorreading the note at the top of the spare part page says there could be 2 hoses depending on motor
looks like 1 hose is the same both ends whereas the other is not
DaveMarch 9, 2019 at 4:19 pm #460424Gazza.simpkins@gmail.com
ParticipantHi Dave, the dishwasher is fixed! Took a bit of doing as the hose the split was in was integral to the motor, but after the use of a craft knife that was soon off. Many thanks for your help, the Mrs is very happy!
March 9, 2019 at 4:45 pm #460425Gazza.simpkins@gmail.com
ParticipantThe motor now sound different though. Hope that’s not on its way out!
March 22, 2019 at 9:33 am #460426Gazza.simpkins@gmail.com
ParticipantHello again. The dishwasher is now displaying F4 fault, after I open it and press the start button it completes the cycle.can I ignore it or do I have to pull the damn thing out again? Cheers
