murv wrote:I use skyprog (with the USB FT232RL interface) for arcadia boards. Have had mixed success writing the older EVO2 boards but an eeprom programmer has always been 1st choice for sorting them.
So, I didn’t understand if you get rid the12’th error?, when the usual bluetooth nor USB programming does not getiing place( when it gives “no ident talbe” or does not connect).
You can see this cases on bluetooth key when blue led is lighteen and just one of yelow from two leds is blinking (just receiving not togheter with emiting led). In this cases (when microprocessor isn’t dead by mean in scc) you have to flashed it with entire content even SW not only the EEP file (configuration) and that is possible only in bridge connection or in MODE3. In this modes you need to have SW file (S19 format) and delete and overwrite him, or you need to know SS/ID code otherwise you aren’t able to read/write SW.
baron
