Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Indesit IS70C Condenser Dryer Not Collecting Water
- This topic has 20 replies, 4 voices, and was last updated 16 years, 1 month ago by
invisiblesystem.
February 28, 2010 at 8:32 pm #313407
invisiblesystem
ParticipantRe: Indesit IS70C Condenser Dryer Not Collecting Water
sounds good as i think i have fluff reblock already from after using extended paper clip!
i want to do this but i don’t know where the condenser is!?
thanks again your a GREAT help:)
February 28, 2010 at 8:38 pm #313408Penguin45
The condenser is the metal monobloc which you pull out and clean regularly. Water collects under it and runs to the back. The hole in the collection chamber joins to the moulding right at the back. Helo is (rightly) suggesting that you reach in and scrape out any fluff manually – as well as poking the hole through.
February 28, 2010 at 8:42 pm #313409invisiblesystem
I always wondered what that big dirty thing did when I pulled it out! 🙂
Thanks guys…
February 28, 2010 at 9:49 pm #313410invisiblesystem
gave the condenser a good clean and we re poke the inlet, can’t feel anything up behind the condenser apart from plastic housing and a warmish metal pipe!
February 28, 2010 at 9:56 pm #313411invisiblesystem
ignore that left the paper clip through from outside, found it in side and pulled it through, cleaning small gap at the bottom!
thanks guys, all should hopefully work now 🙂
big saver, can get a shirt ready for work and t-shirt that doesn’t smell now!
September 13, 2015 at 2:19 pm #313412nicke
Sorry to jump on someone else’s thread here but I have a very similar problem and have followed many of the steps mentioned here.
I have an indesit 1570s condenser dryer. A little while ago we realised that it was not getting hot so I replaced the heating element which now clearly works.
However, we’re not getting any water collecting in the removable drawer / reservoir. I’ve cleaned the condenser several times and have put my hand right to the back to check there’s no fluff blockage at the back. I’ve also checked that the pump is working. It is but it runs dry most of the time as no water gets to that part of the machine.
I’ve cleared fluff from anywhere else obvious. The drum does get hot and things do dry but it takes ages and there is no water collecting anywhere.
Can anyone suggest what else I can do?
many thanks
