Indesit Smart Card
Viewing 15 posts - 1 through 15 (of 21 total)
  • #42712
    JOHN CLARKE
    Do we need a different card for each model or does one card serve all, anybody help please.
    #274588
    nigegt
    Re: Indesit Smart Card
    As far as i know each model has its own card and each card can only be used once
    Nige
    #274589
    JOHN CLARKE
    Thanks nigegt,
    Does anybody know the Part No’s for the different cards, this seems bit of a minefield to me. Why do Indesit not supply the card with the module, I’ve got a module for a dishwasher FDW80P on fitting it I get A09 fault code, communication problem, where do you go from here?
    #274590
    helo_75
    your supposed to use servicenet/partfinder to get the right card umber
    oh and ull need a smartcard reader to programme it
    #274591
    JOHN CLARKE
    Thanks helo 75, How do I get Servicenet/pathfinder
    #274592
    I didn’t think you needed a smart card for the basic dishwasher 100 bit timer PCB’s ❓
    There are two different ones for this model though.
    You can get the Partfinder disc direct from Indesit, it costs big time and lasts less than 9 months most of the time. 😥
    JOHN CLARKE
    Thanks iadom, the dishwasher I have a problem with has a plug for the hardware key so I think I do need a smart card and smart card reader. So how do I go about getting Pathfinder?
    #274594
    The later production of this machine appears to have different electronics.
    Even after you have obtained the smart card you still need a card reader to use it.
    Partfinder is available direct form the Indesit Company 😉
    What is the serial number of your machine?
    JOHN CLARKE
    Serial No = 611290552
    #274596
    Flyman
    As far as I know this model is still using an eeprom, part number C00145652, and module C00143224.
    #274597
    helo_75
    youll be lucky to get an eprom now
    #274598
    JOHN CLARKE
    Thanks Flyman, but I think the EEPROM comes “BLANK” so I will still need to programme it.
    #274599
    Flyman
    Eeprom is still listed as available. There is no smartcard available for this model so far.
    #274600
    stripey
    There is a Tech Buliten out about AL09 errors I cant remember the serial numbers that it relates to but the way around the problem is this.
    Ensure the dishwasher is switched off.
    Remove the 4 wires that go to the display card, orange in colour.
    Switch the dishwasher on for 20 Seconds.
    Turn off again.
    Remove the eprom.
    Reconect the 4 wires going to the display card.
    Put the thing back together again and Bobs your aunty.
    HTH
    #274601
    JOHN CLARKE
    Thanks all, but I might be acting thick but I will still have to purchase a blank EEPROM, how do I programme it.
    The original problem was the dispenser not operating, the soleniod tests OK so I blame the module, then I get into this pickle, brand new module fitted on the machine AO9 appears on the screen, UGH! I can’t see a EEPROM fitted but 8 holes where I think one should be, there started my headache. Thinks order EEPROM,find it on Connect “BLANK” get out of that one. Ofcourse the friendly engineers on Whitegoods will help, please put me straight.
