Indesit washing machine iwc6105
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit washing machine iwc6105
Viewing 15 posts - 1 through 15 (of 18 total)
  • #79158
    Stu ilz
    All the lights come on but it does nothing
    Humming noise from machine
    Any ideas?
    #408207
    Re: Indesit washing machine iwc6105
    Is the water fill tap turned on? Will it drain and spin if set to a spin programme?
    #408208
    Stu ilz
    Yes water turned on
    I have taken off all pipes and they are all clean. Also checked filter in front of machine
    Don’t know if I can reset programme, seems to be stuck on original program
    #408209
    A humming noise is either the fill valve trying to let water in when the is no supply to the valve or the drain pump or main motor trying to run.
    Can you pull the machine out and listen to it, does the noise appear to come from the top, left, rear corner of the machine or lower down?
    #408210
    Stu ilz
    I will pull it out and see where the noise is coming from when I get home
    I tried to put a spin or rinse setting on but all it did was lock the door and all the lights come on. I can pause it but nothing happens when I play
    Will update location of noise shortly. Thanks
    #408211
    Stu ilz
    All lights are now flashing and it is making a noise ?
    #408212
    What sort of noise, where from?
    All lights flashing was a common fault on the earlier modules with a quick fix but not on this one. 😥
    #408213
    Stu ilz
    Noise as in pumping water
    Engineer is £45 call out plus parts 🙁
    Machine is not that old. Just out of warranty
    #408214
    But it is an Indesit . 😉
    #408215
    Stu ilz
    Yes I know. Lol. You sound just like my father 😀
    Used to having Miele at parents….
    Whining noise is coming from bottom left at back.
    #408216
    Hmm, nothing mechanical or electrical bottom left, nearest thing there is the main motor. ❓
    My daughter always listens to me ( as far as anything electrical or mechanical goes anyway) that’s why she has an ISE. 8)
    #408217
    Stu ilz
    There is a circuit board bottom left looking at the machine from the back
    Buzzing noise coming from it
    I should have bought Miele but had to buy all appliances as new house :-/
    #408218
    Andy jones
    Sounds like the transformer buzzing
    #408219
    Stu ilz
    Andy jones wrote:Sounds like the transformer buzzing
    Is that a common fault, big job? Thanks
    #408220
    Andy jones
    It could be if the board needs replacing. As said above it is an indesit 🙂
