Indesit WD12 drainage/noise problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WD12 drainage/noise problem
Viewing 9 posts - 31 through 39 (of 39 total)
  • #156602
    Dave_Conway
    Re: Indesit WD12 drainage/noise problem
    WolfyUK wrote:It’s coming up to two weeks without a washing machine now, so it may be time to call in the pros before xmas…
    I think that may be the best solution to be honest 😉
    #156603
    In your last photo, what is that white plastic looking strip behind the top impellor blade I wonder???
    #156604
    WolfyUK
    I think that is just the camera flash reflecting off drips of water within the unit. 😕
    I’m going to try your Repairs@ service methinks.
    #156605
    Agree with Martin, there does appear to be sometihng stuck inside the pump at 12.00. Part of it looks like a plastic curtain hook. There is definately something behind the top blade of the impellor as well in that picture.
    Circled in red.
    #156606
    WolfyUK
    Hmm… I just took another photo for comparison:
    BTW: it’s at 6, not 12 o/c… the photo is upside-down! I forgot to rotate it earlier, and haven’t with the one above, neither.
    #156607
    What on earth is that four legged thing? Its making my neck ache trying to view it the right way round, it could be part of the moulding of the pump housing, but I don’t think it should be there.
    There still appears to be something black behind the impellor, unless it is a shadow, or possibly the water residue.
    Edit. 😳
    Have you tried running the pump without water and with the filter removed?
    #156608
    Dave_Conway
    iadom wrote:What on earth is that four legged thing?
    A reflection of the impellor I think 😉
    http://www.specsavers.co.uk 😀
    #156609
    😳 now I have turned it the right way up and had a closer look I fear you could be right Dave. still worth trying the pump without the filter and no water though.
    #156610
    WolfyUK
    I just had someone round to have a look… and it worked straight away for him! 😕 The only thing he did differently was to start the machine on a normal cycle before attempting to drain.
    It is definitely more noisy than the old pump, though. 😐
