Indesit WIDL146
  • #38582
    maltheviking
    What a pain in the ar8e this one is 😥
    Replaced the module and eeprom damaged through condensation. I thought the condensation was due to a hole in the wall behind the machine 😥
    Further investigation revealed that when the dryer is on after about 20 mins. steam starts to come out of a hole on the heater box (immediatly above the fan to the rear of the fan motor) The steam then condensates on the inside of top cover and eventually runs down the wiring loom on to the module 😕 Further to this steam starts to come out of the soap drawer
    For the life of me I cannot understand why there should be a manufactured hole in the heater box and why there is no means of the soap drawer to tub hose (trap) being kept topped up with water when drying.
    Anybody shed any light on this lot ❓ or do I just put it down to the usuall high standard of design from Indeshit.
    #259326
    lerch
    Re: Indesit WIDL146
    From serial number 80414.0000 a new style dispensor hose with an intergal weir has been develoed to over come the problem of steam escaping during the drying process.
    Old style part number:- c00115450
    New style part number:- c00260015
    hope this helps 😀
    #259327
    Flyman
    Re: Indesit WIDL146
    You can also get a clear plastic cover to go over the module to protect from water drips. Don’t have the part number to hand at the minute.
    #259328
    Re: Indesit WIDL146
    Tesco plastic bag? Failing that try Morrisons? 😛
    #259329
    maltheviking
    Re: Indesit WIDL146
    Flyman wrote:You can also get a clear plastic cover to go over the module to protect from water drips. Don’t have the part number to hand at the minute.
    Thanks Guys
    This is water running down the wiring loom right to the base of the module, I can’t see a cover stopping it 😥
    What I need to know is why there is a hole in the dryer box that allows steam to escape in the first place 😕 . what you don’t need in a appliance with electronics is steam condensating everywhere 😕
    #259330
    maltheviking
    Re: Indesit WIDL146
    Anyone else any ideas to the “hole”/condensation problem with this begger?
    #259331
    maltheviking
    Re: Indesit WIDL146
    photo shows hole (vent)
    #259332
    Re: Indesit WIDL146
    I know what I’d do – plug it.
    roly16
    Re: Indesit WIDL146
    But all your posts tell us to Unplug it
    #259334
    Re: Indesit WIDL146
    That’s There – not Here.
    Any time you feel like joining in……..
    :p45:
    #259335
    roly16
    Re: Indesit WIDL146
    Or you can get this
    http://cpc.farnell.com/jsp/level5/modul … 265698.xml
    #259336
    maltheviking
    Re: Indesit WIDL146
    Penguin45 wrote:I know what I’d do – plug it.
    Have done 😉 , really need to know why it’s there
    I am not really a fan of covering things to stop water/condensation getting into things although sometimes you have no option :rolls: , I would rather sort out the origin of the problem
    #259337
    effzedarr
    Re: Indesit WIDL146
    I’d be tempted to put a hose on it then route it out of the m/c & either point the hose down or up so as to let the steam flow out, bit like a vent hose on a car/bike engine from the coolant reservoir!
    #259338
    helo_75
    or clean the condenser out so it can deal with the steam in its own environment
    #259339
    Re: Indesit WIDL146
    Attended a Hotpoint WD640G today, power board dead – evidence of water tracks. Dryer unit had the same hole in the top, but closer inspection revealed that the blower housing to tub gasket was only fitted on three sides…..
