indesit wixl123s issue
Viewing 15 posts - 1 through 15 (of 17 total)
  • #97082
    Soulfly83
    My indesit wixl123s wont spin. It fills with water then soon as it should move on to spin , nothing happens. I can only hear a couple clicks. The drive belt is still on place, it drains the water and the filter has recently been cleaned. Any helps appreciated
    #466025
    Soulfly83
    The clicks arnt loud, also for a long time we’ve had to give the door a extra push after closing to get it to lock and washing to start.
    #466026
    does the drum turn at all ? even on wash ?
    if no check brushes if it has them
    Soulfly83
    It doesnt turn at all
    #466028
    Definitely, those look like CESET motor brushes like these. https://shop.ukwhitegoods.co.uk/c00296122-washing-machine-carbon-brush
    #466029
    Soulfly83
    I bought a cheap set off amazon, hopefully not made of chocolate. Cheers
    #466030
    they wont be as good as the gen ones
    keep the loads lower and use only low spin speeds starting at 800 for the first 20 washes to give the brushes a chance to bed in. The non gen brushes need more time to settle in
    Soulfly83
    Sounds like a plan, thanks
    #466032
    Soulfly83
    Ones I got are different, doh
    Similar but different, serves me right for going with cheapest option.
    #466033
    The ones in our online shop are the right ones with the brush ends at the correct angle.
    #466034
    Soulfly83
    there not even close, completely different mounting
    if you want a quality part use the gen part linked above
    if you want a cheaper alternative try
    https://shop.ukwhitegoods.co.uk/d240…carbon-brushes
    but I have stopped fitting some pattern parts due to a lowering of quality over the last 10 years
    Totally different, those are for a Welling motor not a CESET.
    #466037
    Soulfly83
    Bought ones you first recommended, arrived today. Machine is working now. Just put it on a spin. Can it be used as normal now?
    #466038
    If it sounds smooth on spin with no crackling noises then you should be fine.
