Induction v ceramic hob and flush fit
Home Forums Public Support Forums Buying Advice Induction v ceramic hob and flush fit
Viewing 15 posts - 1 through 15 (of 17 total)
  • #60678
    Annemarigold
    In the last stages of choosing a new hob.
    Wanting induction for looks etc and also greener but wondering whether to have one where there are 2 induction and 2 normal ceramic on one hob so as to use non-inductions pans. Any thoughts?
    Also wondering whether to have flush fit. Can’t quite envisage these. Is there a gap (albeit tiny) between top and hob which has to have silicone or similar? Sounds naff?
    #343191
    don
    Re: Induction v ceramic hob and flush fit
    Have you come across one with two of each then? As all the ones I have come across have been one or the other.
    I presume when you say flush fit you are thinking of a frameless glass like this Neff? I would seal it down with silicon just to stop any food particles getting trapped.
    HTH 🙂
    Don
    #343192
    Annemarigold wrote:Wanting induction for looks etc and also greener but wondering whether to have one where there are 2 induction and 2 normal ceramic on one hob so as to use non-inductions pans. Any thoughts?
    Yes, either all induction or all halogen (you said “ceramic” but I guess you were referring to halogen?) but not both together, pointless really. 🙂
    #343193
    Annemarigold
    Yes AEG do one with 2 halogen and 2 ceramic Highlight zone (their words). Model HK634110FB.
    The idea for me would be having induction which is what I want but the others for use with any old pan I might have.
    I don’t know what type the Highlight is. They just say ceramic
    #343194
    Annemarigold
    As for the fit there seems to be 4 types, one or more SS edged edges, frameless which sticks up above with a 90 deg edge, bevelled/chamfered which also sticks up but with a gentler edge and flush which means it is level with the worktop and doesn’t stick up at all.
    Such as this one:
    http://www.siemens-home.co.uk/our-produ … rce=browse
    #343195
    don
    Annemarigold wrote:Yes AEG do one with 2 halogen and 2 ceramic Highlight zone (their words). Model HK634110FB.
    I thought you had found an induction/ ceramic mix, which I knew nothing of 😆
    Indeed as you have found out there are quite a few choices to be made when it comes to style and design.
    when it comes to installation you will need to allow adequate ventilation for the fans to function correctly and as such they can only be installed over a single oven as per the manufacturers instructions.
    Don
    #343196
    Annemarigold
    Don you have confused me as the AEG is a mix of ceramic and halogen.
    As for the flush one (different model) it’s quite what it looks like I am after. I
    have seen lods that sit on the work top but not a flush one
    #343197
    don
    Not trying to confuse you honest, I was referring to your original post.
    Don
    #343198
    Annemarigold
    Exactly. This model has both ceramic and induction:
    http://www.aeg.co.uk/Products/Cooking/H … HK634110FB
    model HK634110FB
    #343199
    don
    Not having been asked for that combination before I did not realise there was such an item, but I do now.
    Thanks for that 😀
    Don
    #343200
    Annemarigold
    What do you think of the idea?
    #343201
    don
    Sounds okay, it certainly will save on having to buy a whole set of new pots and pans, just a few favourites to start with.
    What I don’t see is why have ceramic plates when induction uses less energy, plates heat quicker, very little residual heat remains once pan is removed and are easier to control.
    Don
    #343202
    Annemarigold
    #343203
    don
    If I was going to spend £600 on an electric hob I would definately go all induction.
    #343204
    Annemarigold
    That’s what we thought except when you’ve been around a while you inevitably have some pans that won’t be compatible.
