Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › INTERGRATED WASHING MACHINES
- This topic has 16 replies, 4 voices, and was last updated 19 years, 8 months ago by
handwash.
August 8, 2006 at 8:44 pm #19796
handwash
ParticipantHi there 1st post be gentle
Just over a year ago we had a new kitchen fitted includung fancy new intergrated washing machine think it is MFI own make the cooker is a diplomat range
Machine refuses to spin,drain out water and is very noisy(GRINDING SOUND)
Warranty is up 😥 and manufacturar wants £90 to visit me with no guarantee of repair.
Local repair shop was very polite but not interested .
Sorry for such long post could you recommend a washer dryer willing to pay reasonable price or are allintergrated machines dammned 🙁
ThanksAugust 8, 2006 at 9:41 pm #184552gegsy
ParticipantRe: INTERGRATED WASHING MACHINES
Have you tried draining it down and checking for foreign objects in the filter and drain pump area? It sounds as if something is in the pump housing to be honest.Unplug appliance before attempting any investigations 😉
August 8, 2006 at 9:49 pm #184553Dave_Conway
It’s probably the pump so it won’t be an expensive repair.
Check the repairs@ link below, you should find someone there that can help 🙂
August 8, 2006 at 9:50 pm #184554Dave_Conway
:waving:
August 8, 2006 at 9:52 pm #184555gegsy
:dave: 😆
August 8, 2006 at 11:21 pm #184556Penguin45
Might be an idea for our poster to find the actual model number, then we can advise him how complex or simple this might be………
August 9, 2006 at 6:33 am #184557handwash
tahnks for replies off to work but will be right on the case and will get back to you with numbers etc
thanks again 🙂 🙂August 9, 2006 at 9:27 pm #184558handwash
model no on manual readsAPM 8522.
I unscrewed filter it was clear ,removed some pipes (rubber) adj /feeding into filter again clear.
Strange thing happened machine when through full wash and spin still noisy but washing spunvirtually dry 😀 😀
Did another wash back to square one no spin and water still in machine have had to drain it manually.
Again many thanks for replies ,my better half pushing to go shopping this weekend suprise,suprise.
Will look at contacts you have given for local repairers
CheersAugust 9, 2006 at 9:50 pm #184559handwash
thinking of contacting a local independent repairer no this sounds stupid but would you know the manufacturer of my machine from the model number above .
Manual does not give a name HONEST 😳 😳August 9, 2006 at 9:53 pm #184560gegsy
ParticipantAugust 9, 2006 at 11:51 pm #184561Penguin45
Just change the pump, it’s this one:
http://www.ukwhitegoods.co.uk/modules.p … cts_id=162Far cheaper than buying a new machine. Admittedly it’s not the finest washer ever built (integrated ones seldom are), but perfectly adequate.
Penguin45.August 10, 2006 at 11:43 am #184562handwash
Many many thanks know I am being a pest 😳 my model number did not show up in the list shown that pump could be used for ,take it is still ok ,model no was APM 8522 🙂
I am up for ordering part I am ok with general DIY is there much in fitting new pump or somewhere I can read through procedure.
Once again much obliged for the time and trouble for your replies,I will keep you in the loop if you can just confirm it is correct part .
Kind Regards
August 10, 2006 at 12:20 pm #184563Dave_Conway
handwash wrote:model no was APM 8522 🙂
Yep, that’s the correct pump in that case 😀
August 10, 2006 at 7:54 pm #184564handwash
Thanks Dave didn’t doubt u for one moment 😳
The wife however doubts I can pull this off 😯 , part ordered due to arrive next 2 to 5 days.I am up for it any last minute bits of advice.
You would think I WAS ABOUT TO PERFORM OPEN HEART SURGERY 😳 😳
Cheers keep up the good work 🙂
August 10, 2006 at 9:47 pm #184565Dave_Conway
handwash wrote:part ordered due to arrive next 2 to 5 days.
Probably faster than that, it’ll go tomorrow 😀
Just remember to power off :zap:
